Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Are you running Vista? If so make sure you are running Vue in Administrator mode before starting any Hypervue renders.
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
From our good friends at e-on, this is how you do it:
To recover .tmp tile files, please run Vue with the following command line option:
Vue 6 Infinite.exe -t"[PATH TO YOUR DIRECTORY HOLDING TMP FILES]"
for example, if your tmp files are in "c:/TmpFilesDir", you have to launch Vue with:
Vue 6 Infinite.exe -t"c:/TmpFilesDir/"
Make sure you have a trailing slash on the directory name or it will not work! It took me about five times to get it right.
My Vue likes to complete a network render but sit at 100% and not stitch together the tiles it generated... It's getting rather annoying. Is there a way to put them together to make a completed image? I tried opening them up in Photoshop but it doesn't seem to recognize the file format.
