Tue, Nov 19, 11:58 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Stitching Together Failed Network Render
Kaji ( ) posted Mon, 23 July 2007 at 12:10 PM · edited Tue, 19 November 2024 at 11:49 PM
My Vue likes to complete a network render but sit at 100% and not stitch together the tiles it generated... It's getting rather annoying. Is there a way to put them together to make a completed image? I tried opening them up in Photoshop but it doesn't seem to recognize the file format.
bruno021 ( ) posted Mon, 23 July 2007 at 12:25 PM
What's in your scene? Is it a big render? With a spectral atmosphere?
I don't think you can stitch the tiles together in a paint program, because they are not an image yet.
chippwalters ( ) posted Mon, 23 July 2007 at 2:08 PM
I think HyperVue does some post processing of the image (aka "Lens Blur") after the tiles are stitched together. On my machine it does take longer to process the tiles if I've added post proccessing. On a very large image, this can take a few minutes.
HTH, Chipp
Kaji ( ) posted Mon, 23 July 2007 at 2:12 PM
I think it's a bug. It's happened on an image that was only about 1000x1000 and I left it running over night... after 9 hours it still said 100%.
This particular one was 1920x1200 with a standard atmosphere and standard illumination, took 38 minutes and sat there for an hour at 100%.
chippwalters ( ) posted Mon, 23 July 2007 at 2:32 PM
Yup, sounds like a bug to me. You might try sending in a bug report to e-on with the file in question.
best,
Chipp
Jonj1611 ( ) posted Tue, 24 July 2007 at 3:09 AM
Are you running Vista? If so make sure you are running Vue in Administrator mode before starting any Hypervue renders.
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
Kaji ( ) posted Tue, 24 July 2007 at 6:04 AM
Yeah... I have Vista on the rendering box. I turned off UAC so it wouldn't bother me anymore, but it was already set to run as administrator.
Sometimes it works and sometimes it doesn't, so my guess is it is a "feature"... I mean bug ;)
Kaji ( ) posted Wed, 25 July 2007 at 6:04 PM
From our good friends at e-on, this is how you do it:
To recover .tmp tile files, please run Vue with the following command line option:
Vue 6 Infinite.exe -t"[PATH TO YOUR DIRECTORY HOLDING TMP FILES]"
for example, if your tmp files are in "c:/TmpFilesDir", you have to launch Vue with:
Vue 6 Infinite.exe -t"c:/TmpFilesDir/"
Make sure you have a trailing slash on the directory name or it will not work! It took me about five times to get it right.
chippwalters ( ) posted Wed, 25 July 2007 at 7:00 PM
What do you mean "recover .tmp files"? Does this stitch them all together? With or w/out post effects?
Kaji ( ) posted Wed, 25 July 2007 at 7:06 PM
This is making the HyperVue tmp files into bmp files. You'll have to put them together in Photoshop yourself. I don't use post effects so I'm not sure what happens with those.
