Fri, Jan 10, 11:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: lost parameter dials p5
size8 ( ) posted Mon, 23 July 2007 at 8:17 PM · edited Fri, 10 January 2025 at 11:39 PM
I have Poser 5 and dont know what i've done but i used to be able to double click on a character/item of clothing etc and the parameter dials would appear but now they dont and i cant seem to get them to appear no matter what i do, if something could be moved and looked under i looked under it.
I tried window/parameter dials but they are ticked as on in there ( i unticked and ticked them again just in case) I also tried shift/ctrl/N but nothing happened. I've tried switching options to load in factory state.
I've uninstalled and Re-installed (making sure prefs was deleted first) and I've now uninstalled and removed everything then done a totaly clean new install and still nothing...
(would the fact that i have it all backed up on my spare D drive make a difference ? )
oh and i rebooted after everything i tried.
help pleaseeeeee
ockham ( ) posted Mon, 23 July 2007 at 9:54 PM
If you've reinstalled and still have the problem, it sounds like a virus.
Once I had a virus that grabbed one of Poser's DLL files and
kept on re-inserting itself on each new installation.  If you can re-install
to a different folder, it might help.  That is, remove all of Poser's stuff
everywhere on your computer, then install to a different location from
the default.
If it's not that deep, one other thing you might try is the interface switch.
In Poser, type
PO2
(just the letters and numbers, no return key or anything)
This will switch to a standard Windows-style interface, where you
*may *be able to see the edge of the parameter box off in one corner
of the screen.  Pull it back to normal, then type
PO3
to return to normal Poser interface.
My python page
My ShareCG freebies
size8 ( ) posted Tue, 24 July 2007 at 5:05 AM
I feel realy silly now.. where in Poser do i type PO2 ?
Paradox1998 ( ) posted Tue, 24 July 2007 at 5:55 AM
If you no longer get a parameters dial window because you've inadvertently closed it, go to the window menu. Scroll down and you will see a parameter window choice. Click on it and it should  re-open that window for you and give back your dial controls. Hope this works for you.
ghelmer ( ) posted Tue, 24 July 2007 at 6:10 AM
Or just "ctrl" & "i" should open it too....  did you resize your desktop maybe and it's hidden off to the side perhaps?
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
EnglishBob ( ) posted Tue, 24 July 2007 at 6:16 AM
Quote - .. where in Poser do i type PO2 ?
Anywhere. ;) - Except if you have a field waiting for input, of course.
lesbentley ( ) posted Tue, 24 July 2007 at 2:37 PM · edited Tue, 24 July 2007 at 2:38 PM
If you have saved any UI Dots, applying one may do the trick. If not, try increasing Windows screen resolution, then max-size Poser and see if you can see the Paramiter pallet now, if so drag it to center, then reset windows resolution.
size8 ( ) posted Wed, 25 July 2007 at 6:34 AM
it was the windowa resolution its all back now, Thanks everyone :)
