Attached Link: http://www.microsoft.com/technet/sysinternals/FileAndDisk/PageDefrag.mspx
Have you changed anything on your PC (I assume it *is* a PC)? Check out the memory updater if you've added RAM. The other thing that seems critical is the health of your virtual memory page swap file. I eventually put mine on a separate partition to everything else; how you do this will depend on your version of Windows. I do hope it isn't '95. ;P Whether or not you move your page file, I'd recommend Sysinternal's pagedefrag. Normal defragmentation doesn't touch the page file, or several other essential bits of disk space. Pagedefrag will keep your PC healthy.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Yes, some of us old farts still use P4. Anyway, opened it up as usual and three quarters of the working window is white. When i try to render i (eventually) get the old 'out of memory' message. I've played around with increasing the virtual memory but still no joy. I've even installed P4 onto a seperate drive but i get the same thing. Any gurus out there got an idea as to what's going on?
