Sat, Jan 11, 12:19 AM CST
Subject: Why does Poser change my settings?!
muralist ( ) posted Wed, 25 July 2007 at 9:24 AM · edited Sat, 11 January 2025 at 12:17 AM
I have a single poly plane as a sea.  When i set the Displacement Bounds, Poser randomly changes the setting.
I have a light set consisting of an IBL with shadows on and a Spec only light.  When I save the light set then reload it, the IBL shadows are turned off.
Also my preview settings never save Hardware Shading checked.  What is the problem?  I have enough to do without having to reset every parameter each time I use the program.
Why?
4blueyes ( ) posted Wed, 25 July 2007 at 10:27 AM
IBL light cannot be used for shadows, maybe this is why Poser turns the shadows off on it? No idea about the rest of the problems though ... Michal 4blueyes
muralist ( ) posted Wed, 25 July 2007 at 10:50 AM
IBL light can be used for shadows.
Gareee ( ) posted Wed, 25 July 2007 at 11:11 AM
Once you changed your poser settings, did you also set poser to USE your settings the next time it starts up as well?
muralist ( ) posted Wed, 25 July 2007 at 11:17 AM
Yep.
Miss Nancy ( ) posted Wed, 25 July 2007 at 1:50 PM · edited Wed, 25 July 2007 at 1:52 PM
just to confirm - IBL can be used with ray-traced shadows, if one wants to avoid AO and speed things up. poser turns off shadows on me, as well, when changing from a directional lite to an IBL. as mentioned, this is likely due to the coders' belief that one should use AO with IBL, and not shadows, perhaps in regard to users' inability to understand shadowlite cams, map size, et al. displacement bounds seem to change at random. I don't know if render settings for DB over-ride object properties DB, but it's the object properties DB that change.
muralist ( ) posted Wed, 25 July 2007 at 2:18 PM
Yeah, its the random Displacement Bounds that are causing me grief.
I have AO and raytraced shadows on on the light.  Do you only use one or the other?
Miss Nancy ( ) posted Wed, 25 July 2007 at 3:00 PM
ray-traced shadows and AO would probly seem a good idea if one is getting poor shadow detail from ray-traced shadows alone, but AO is redundant if one knows how to zoom in on the shadowlite cam IMVHO.
muralist ( ) posted Wed, 25 July 2007 at 3:29 PM
How does one zoom in on the shadowlite cam?  Er, a friend wants to know.
Miss Nancy ( ) posted Wed, 25 July 2007 at 4:56 PM
click on the camera drop-down list, then see if there's only 1 shadowlite cam. in my case, they get renumbered for some reason, hence I hafta guess which one is right. then click on one of the camera controls on the left, and the shadowcam parameters will appear on the right. depending on version, there will be a dial for "zoom" or "scale". decrease the number on the dial to zoom in. adjust x and y values to keep the object centred.
