Tue, Jan 7, 4:32 PM CST
Subject: How to uncompress .obz files? (lost the thread)
Colin_S ( ) posted Fri, 27 July 2007 at 9:21 AM · edited Tue, 07 January 2025 at 4:11 PM
There was a thread on this but I can't find it. Anyone know where it is, or how to do it?
vincebagna ( ) posted Fri, 27 July 2007 at 9:28 AM
You have to open the script python window by clicking on "window", then choose Utility funcs, then uncompress files.
Acadia ( ) posted Fri, 27 July 2007 at 9:29 AM · edited Fri, 27 July 2007 at 9:30 AM
Open Poser.  Go to your Windows menu (I think). Find the Python Scripts".  Click "Utilities", and then "Uncompress files".  Browse to the folder you want to uncompress (doesn't have to be the runtime folder itself, it can be one of it's sub folders). Check the box next to "uncompress geometries" and click "run".
EDIT:  Cross posted.  But yeah, what Vince said.
vincebagna ( ) posted Fri, 27 July 2007 at 9:35 AM
You were more detailled than me. But he... you have a magic globe, it's easier for you! :tt2:
Acadia ( ) posted Fri, 27 July 2007 at 9:37 AM
LOL.  I've been planning on making a new avatar, but I'm clued out.  My poser faces suck, and I don't know what else to make.  I at least have to redo this one because of the ugly border around it now that the site colours have changed.
vincebagna ( ) posted Fri, 27 July 2007 at 9:43 AM
No no, it's nor ugly. (never oppose to a woman...) he he ;)
thefixer ( ) posted Fri, 27 July 2007 at 9:45 AM
Tick both check boxes or you will have duplicates taking up space on your HD, if you don't tick both, you'll have a compressed version and an uncompressed version of the files!
Injustice will be avenged.
Cofiwch Dryweryn.
Colin_S ( ) posted Fri, 27 July 2007 at 10:47 AM
Done it now,  thank you both.
Little_Dragon ( ) posted Fri, 27 July 2007 at 2:42 PM
Just for the sake of thoroughness, I thought I'd mention that you can open Poser's compressed files with most file-archiving utilties, including WinZip.  They use standard zlib compression algorithms.
Dimension3D also has a free utility (Poser Compressor) that will uncompress files.  You can get it here:
http://www.ralf-sesseler.de/d3d/
http://www.renderosity.com/mod/freestuff/index.php?user_id=288865
Acadia ( ) posted Fri, 27 July 2007 at 3:05 PM
Quote - Just for the sake of thoroughness, I thought I'd mention that you can open Poser's compressed files with most file-archiving utilties, including WinZip.  They use standard zlib compression algorithms.
I've never been able to unzip them using Winzip. How do you user Winzip to open them?
Little_Dragon ( ) posted Fri, 27 July 2007 at 3:21 PM
Right-click the file --> Open --> Select program from list --> WinZip
Acadia ( ) posted Fri, 27 July 2007 at 3:31 PM · edited Fri, 27 July 2007 at 3:32 PM
The only choices I have for Winzip when I right click one of those files is to add or zip and email. With Winrar I can add or compress.  Nothing about unzipping or opening.
nruddock ( ) posted Fri, 27 July 2007 at 4:11 PM
Quote - Tick both check boxes or you will have duplicates taking up space on your HD, if you don't tick both, you'll have a compressed version and an uncompressed version of the files!
If it's content that came with Poser, the one possible disadvantage to deleting the compressed version, is that if EF issue an update, it will only be applied to the original compressed file.
nruddock ( ) posted Fri, 27 July 2007 at 4:15 PM
Quote - The only choices I have for Winzip when I right click one of those files is to add or zip and email. With Winrar I can add or compress.  Nothing about unzipping or opening.
Changing the extension is probably what's required.
Try using .GZ
thefixer ( ) posted Sat, 28 July 2007 at 3:18 AM
*If it's content that came with Poser, the one possible disadvantage to deleting the compressed version, is that if EF issue an update, it will only be applied to the original compressed file.
*I always delete the original obz and have never had any problems like this!
Cofiwch Dryweryn.
nruddock ( ) posted Sat, 28 July 2007 at 4:00 AM
Quote - *If it's content that came with Poser, the one possible disadvantage to deleting the compressed version, is that if EF issue an update, it will only be applied to the original compressed file.
What I said applies more to content updates, rather program updates.
Depending on how they do them, at best you'll have to uncompress again, at worst the update won't happen.
