Sun, Feb 16, 5:45 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: Apophysis-Backgrounds
sweetlizzard ( ) posted Wed, 01 August 2007 at 8:05 PM · edited Mon, 27 January 2025 at 6:09 AM
Hi-I'm new here- just started working with this Program and I want to know if it's possible to import Backgrounds(not colours-but selfmade images)or export the files/flames with transparent background.....I'm working with the Apophysis2.06beta Version.
I searched all possibilities-didn't find a way to mix the flames with images......
I don't have professional Graphik- Programs like Photoshop, only PaintShop Pro7 and Photo Impact10  and a 3D Program.
It would be really nice if there's anybody out there to help me....Thanks a lot
tdierikx ( ) posted Thu, 02 August 2007 at 3:14 AM
You can render your flames with a transparent background with Apophysis - but you need to render them as .png files - also you need to make sure that you have "Transparency" set to "Enabled in your Options/Display tab.
Once you have rendered your .png file with the transparent background, you can open it in Paint Shop Pro to use as you see fit...
T.
Who? Me?
sweetlizzard ( ) posted Tue, 07 August 2007 at 8:40 AM
Sorry- I was really busied during the last days- your post really helped me out:-)))))))
I'm sooooo happy!
But- I still got the problem that I loose the fine contours of the original flames(it works partly with a high resolution rendering.....but not perfect....)-specially the transparent parts.Do you know any way to lay them over an image?You should see the image through.....(sorry about my english.......I'm germanlol)
I think this would only be possible if I could load an image -file into the background.....but it doesn't look like it's possible....
Greetz
three_grrr ( ) posted Tue, 07 August 2007 at 2:42 PM
When I'm using a png file with a photo for instance, I find the same issue, the .png flame is transparent so the photo shows through. I either layer the .png file over itself several times, giving it more substance, or in a new layer flooded with black or any color you want, i layer the png file, then erase all the background color except that which i want to be behind the png. Then I merge. Now I have a pspimage file, and I can layer that over the photo. Sounds convoluted, I'm sure there is a better and easier way, but I haven't found it yet.
Perhaps someone else has some ideas.
