Thu, Dec 12, 12:54 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Dynamic Clothing and new update
fyrecomix ( ) posted Mon, 06 August 2007 at 1:12 PM · edited Thu, 12 December 2024 at 12:49 PM
Hi all,
Ever since I did the new update, I have not been able to get dynamic clothes to work from P6 to Vue 6 Infinite.  Every time I import, I select only the frame with the completed animation and it brings over a posed character, but the shirt I am using, which I have used before in one of my images, stays at zero point or close to that.
So far, here are the steps I have tried to fix it:
1.  Resaved poser file.
  1. Uninstalled and reinstalled Vue 6 Inf with latest update
I hope someone has been able to fix this, because I was just getting used to dynamic clothes before this happened.  Thanks for any help you can give.
Joe
thefixer ( ) posted Mon, 06 August 2007 at 1:14 PM
My Vue6Inf has never worked right in that respect, [unless that's how it's supposed to work], I always have to import the whole animation for the dynamic cloth to work and also advance the frame to the end frame as Vue brings it in at frame 1.
Injustice will be avenged.
Cofiwch Dryweryn.
estherau ( ) posted Mon, 06 August 2007 at 11:36 PM
I can't bring i a single ie one only animated frame either with the new update - i have intel mac puter
MY ONLINE COMIC IS NOW LIVE
FrankT ( ) posted Tue, 07 August 2007 at 2:35 AM
Online Now!
I tried last night and it seemed to work ok (my last upload - imported frame 60), I'm going to try the morph target route as I want to do some fiddling in Hexagon after I run the sim to smooth some of the jaggies out.
I dunno why mine seem to work unless I was just lucky with the last one.  I've got some more I want to do tonight when I get home from work - I'm currently playing with Velvet shaders in Vue so I need something to work on :)
My Freebies
Buy stuff on RedBubble
diolma ( ) posted Wed, 08 August 2007 at 5:11 PM · edited Wed, 08 August 2007 at 5:17 PM
I am assuming that you want just a single frame from a Poser "clothifying" session. I've never been able to work comfortably with Vue's animation (not enough practise), so I go about it from the "other end"....
In Poser, create and collapse an animation:
  1. Create dynamic animation. (I always try to have extra frames after the end of the posing to allow the cloth to settle. Sometimes needed, sometimes not, but usually better to have the choice.)
  2. Move to the "best" frame of the animation and export just the cloth as a .obj - no options set except possibly "existing groups" for texturing purposes. This is the only way I know of saving "posed" clothing as a single entity.
  3. In the Animation Editor grab the whole of that same frame and move it back to frame #1. Delete the remaining frames (leaving just a single frame).
  4. Delete the clothing then import the saved .obj (again, no option set - especially ensure "% of figure size" cleared.
  5. Save the scene (as a new .pz3 file).
After the above you should end up with a single frame which has both the pose you wanted and the clothing that fits that pose.
Edited to add: The export/import route will lose any special Materials applied to the clothing, including transparancy values. Either re-apply them before saving the single frame, or re-do the materials in Vue (probably better). This is one of the reasons for saving the groups when exporting ...
In Vue:
  1. Import that single frame. Actually, since it's a single frame, you won't have the option of setting a frame number anyway.
  2. errrmmm... there is no 2.
I have Poser 5/6 and V5I. It works with those, so should work with later versions..
Hope that helps,
Cheers,
Diolma
martial ( ) posted Wed, 08 August 2007 at 6:51 PM
In Poser create spawn objet with your dynamic cloth at the frame you find best dynamic morphing  and using it as morph for the prop at the frame 1 , ;delete the others frames;save your Poser file and import in Vue
For me it working but i never did as animation of course.
estherau ( ) posted Wed, 08 August 2007 at 7:26 PM
The animations used to work for me, without needing to do that, but not in the last 2-3 updates. Love esther PS something is actually wrong and we should write to them about it.
