Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
I have no idea why some objs get that "out of range UV coordinate" error. ???
It happens when during UV mapping some vertices extend beyond the range of the texture map. All vertices should stay within the boundary of the texture map in order to get textured properly. If they aren't, there will be some areas that don't get textures applied correctly.
Some of the Poser 5 or 6 figures had that problem, if I recall ... and I think it was the eyes or lashes or something that had some vertices that extended outside of the texture map area.
I finally figured out why some imported head cause FaceShop to crash (but others don't).
The reason is : the UVmap has out of range UV coordinates.
Here's the fix:
But at least UVmapper can fix it.
bB
