Mon, Jan 20, 7:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Poser noob help
Faerydae ( ) posted Sat, 11 August 2007 at 8:06 PM · edited Mon, 20 January 2025 at 7:00 PM
I purchased my first character earlier today - Fayette. I have Aiko 3 installed and she does load in Poser but when I go to the figure tab (and every other tab) in the little libraries box I can't find Fayette. I've googled by behind off and can't find any tutorials or anything that is helping me use her. Please help!
Thank you!
FrankT ( ) posted Sat, 11 August 2007 at 8:23 PM
you should find the textures in the "poses" tab.  Possibly in a subfolder of the tab - try looking for a tab with the makers name on it
My Freebies
Buy stuff on RedBubble
ashley9803 ( ) posted Sat, 11 August 2007 at 8:39 PM
This would have come in a zip folder with the same file structure as where it goes in your Runtime.
Look in the zip and look at the Character, Pose, etc. sub-folder names - these same names will be used  in your Poser Runtime.
Acadia ( ) posted Sat, 11 August 2007 at 9:23 PM
Welcome to Poser :)
I compiled information that is beneficial to a new user, here it is. It answers your current question, plus addresses others that you will probably encounter:
A picture to show you the file structure of a Poser Runtime can be found here:
http://www.daz3d.com/support/faq/index.php?id=94
Unfortunately the above link no longer works. Daz seems to have removed it. I have contacted them and have requested that they put it back, but I haven't heard back from them as yet.
Basically, what it boils down to in a nutshell:
If you are looking for a Character or a piece of clothing/shoes, in Poser you will find them in libraries/character
If you are looking for hair, you will find them in either library/character/hair OR library/hair
If you are looking for character texture addons, hair textures, clothing textures, you will find them in library/poses. Sometimes on the rare occasion, a merchant will package their textures so that they go into the "Camera" folder (.cm2 files). If that is the case then you can either apply them from there, or do what I do and change the file extension to .pz2
If you are looking for props, they are located in library/props
Sometimes you will find clothing and hair or shoes in library/props too, depending on whether the item is actually created and saved as a figure, or it was created and saved as a prop.
Figure items are "conformed" or "parented"
Props are parented.
If you are just starting, it's best to get started on the right foot. DO NOT just install files into the runtime! That will only lead to frustration because you won't be able to find anything, and not all files are packaged equally and land up all over the place.
Here is a link to a tutorial on using multiple runtimes.
http://forum.daz3d.com/viewtopic.php?t=9060&start=0
Another tip is to never just unzip or install anything directly to your runtime. Always unzip or install to a separate folder. Then browse through the folder to have a look at the structure of where things are going and make sure that it's in "proper runtime structure" so that when you move it to the runtime, they get into the proper folders.
Once you get your files installed, the next thing you want to do is to start making things :)
Here are some great newbie tutorials that will get you through the bare basics. They are for Poser 5, but it is still the same in newer versions:
http://trekkiegrrrl.dk/tut1.htm
http://www.poserguide.nimprodaction.com/issues/issue2/cover.htm
http://www.poserguide.nimprodaction.com/issues/issue3/cover.htm
http://www.canary3d.com/tutorial/3d-intro.htm
http://www.ebonshire.net/tut-posb/index.php
http://www.cooltuna.com/poser/poser-tutorials.html
Dr. Geep Studios ( Basic to Advanced Tutorials. Periodically offers free classes for Poser)
http://www.anniescorner.net/posertuts/GettingStartedinPoser5.htm
If you don't have the Daz  V3 or the V4 figure, you should pick one or both. I'd personally suggest that you go with the V3 one as it's been around for years and there is a TON of freebies around for her, as well as a TON of stuff in the various Poser stores.  It will be a couple of years before V4 catches up with clothing content and stuff  and  V3 stuff won't work on V4 because they are different figures. There are work arounds to getting clothing from a figure to fit another figure. I've included information on that further down.  which is a popular figure, you should get it.
Victoria 3
3D Models Pack  Free from Daz at Download.com
Victoria 4
But if you want to change the look of her face and body, or use any of the available character addon packages, you need to buy the head and body morphs.
The V3 head and body morphs are here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3008
There is also "Michael 3".  He is available free at the link above at download.com.  Again, like Vicky, you need the head and body morphs to change the shape of his head and body. Those can be found here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3009
If you have both figures, you can get both of their head and body morphs in one package, here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3010
NOTE:  You can use the textures from the character addon packages without having the head/body morphs.
If you want to change the look of the head/body and have the head/body morphs, do the following:
Install the head and body morphs.
Locate the morphs you want to use in the "Poses" folder.
Find the set of morphs you want to inject IE:  Full Body, Full Head.... or just certain parts.
Left  click the picture
Click the Single Checkmark at the bottom of the page.
Go to your Parameter Dials and start turning dials.  (make sure that you have the part of the body you want to adjust as the active one IE:  Morphing the ears, make sure you have the had selected.
Also, you can find many, many free morphs and textures for Vicky, and Aiko, and some even for David and Michael.  So you don't have to turn any dials if you don't want to.  Here are a couple links to get you started.
http://www.renderosity.com/mod/freestuff/index.php?user_id=55140
http://www.renderosity.com/mod/freestuff/index.php?user_id=178490
http://www.renderosity.com/mod/freestuff/index.php?user_id=105158
Using ready made character addons is pretty easy.   You need to have the figure and it's head and body morph packages installed.
Load up the figure IE: Vicky
Go to the Poses folder, and instead of looking for your morphs from the packages, look for th character you want to use.  Left click the image that has INJ, click the SINGLE checkmark at the bottom and the morphs for that character's look is injected into your figure.  No dial turning necessary.  Of course if you want to tweak the settings you can, but that's not mandatory.
Next locate the textures (if the package has some). They will be usually in the same library menu as your INJ that you used.   Left click the image for the texture and use the SINGLE checkmark to apply it.  If you don't like that texture, apply another one overtop.
You can even use a texture from another package.  IE: Morphs from package A  and textures from package C.  Or morphs from packag A, texture from package C, eyes from package D, lips from package E.  the combinations are endless :)  If the packages have their head morphs seprate from the body ones, you can mix and match morphs too. IE: body morphs from package A with head morph from package D.  That allows for even more versatility.
There are lots of sites out there that has free V3 character addons, and some that have for Aiko, Michael and even David.
Hair, clothing and textures are all figure/item specific, which means:
Michael 3.0 needs hair and clothing and textures made for Michael 3.0
Victoria 4.0 needs hair and clothing and textures made for Victoria 4.0
Victoria 3.0 needs hair and clothing and textures made for Victoria 3.0
Victoria 2.0 needs hair and clothing and textures made for Victoria 2.0
Aiko needs hair and clothing and textures made for her.
Like figures, a texture made for one hair style can only be used on that hair style.
Clothing is also specific when it comes to textures. A texture for a pair of pants, won't fit all pants... just the pants that it was made to fit. Same with all clothing items.
Sometimes you can manage to  clothing item to fit another figure by tweaking of dials and increasing or decreasing the scale percent, but that doesn't always work. Sometimes a clothing item for Victoria 2 will fit Victoria 3, but their joints are different so posing a figure wearing clothing not made for it specifically will be hard.
Some figures can share items more easily than others, here is a link that will help sort that out:
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2682279
There are 3 types of clothing:
Dynamic:  This is clothing that you use inside the Cloth room. It takes longer to work with and there is a bit of a learning curve, but it's not too bad, but the results are more appealing in that the clothing actually looks more natural instead of "posed and stiff".
Confroming- Non Morphing:  This is clothing that you conform to a figure. The clothing is made to fit the base figure.  If you change the shape of the figure you will also have to refit the clothing, which isn't always easy if there aren't any corresponding body morphs in the clothing.  Plus posing a character in positions where they are not nearly upright is difficult.  But many prefer this type of clothing over dynamic.
Conforming-Morphing: This is the same as conforming-non morphing, only there are morph dials that you can turn that have corresponding body morphs for easier fitting.  This is the preferred type of conforming clothing because it's easier to fit.
Using a clothing item on a figure that it is meant to be used on, after you have added morphs and adjusted the shape of the body can be problematic because the clothes are made for the default figure shape and not the new morphed up shape. So the clothing no longer fits and you get parts of the body showing through the clothing after you add morphs and change the shape of the body.
There are programs that can help fit clothing from one figure to another, or even from the same figure to one that has been "morphed up" using their morph packages.
The Tailor, which can be bought here:
http://www.daz3d.com/shop.php?op=itemdetails&item=677
Wardrobe Wizard (I use this one and it's great). It can be purchased from PhilC's site here:
http://www.philc.net/WardrobeWizard.htm
Clothes Converter, which can be bought here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3069&cat=131
Things like hair can be used across all figures just by tweaking the scaling and trans dials and then parenting the hair to the figure.
Poses are something else that can be used across most human-like figures with just a bit of tweaking to dig out a hand, or fix a shoulder.
These are all things I learned along the way and found to be valuable, so I try to pass them along because I know how frustrated I was when I first got Poser.  Hopefully you will find the information helpful.
Faerydae ( ) posted Sat, 11 August 2007 at 9:44 PM
Thank you for your help everyone! I did find her in the poses library however when I load the inj's her face still looks like plain old aiko when rendered. Here's what I'm seeing  http://img74.imageshack.us/img74/238/fayettetestwz4.png and this is what she should look like http://market.renderosity.com/mod/bcs/index.php?ViewProduct=53792
wheatpenny ( ) posted Sat, 11 August 2007 at 9:47 PM · edited Sat, 11 August 2007 at 9:48 PM
Site Admin
Attached Link: Aiko 3.0 Morphs and Maps
Did you buy the Aiko morph pack, or just the Aiko figure? You need the morph pack in order to make the characters work (see attached link)
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Faerydae ( ) posted Sat, 11 August 2007 at 9:49 PM
No I didn't but I am now. Ugh. Well, I said I was a noob and I sure proved it lol. Thank you wheatpenny!
dphoadley ( ) posted Sat, 11 August 2007 at 11:54 PM
Acadia ( ) posted Sun, 12 August 2007 at 12:04 AM
The free base doesn't come with the maps and morphs. You have to buy those.  She bought Fayette, a character for Aiko.
However, if she actually bought Aiko at Daz, then she should contact Daz for a refund because Daz  is offering Aiko free at the links you have posted.
dphoadley ( ) posted Sun, 12 August 2007 at 1:23 AM
"However, if she actually bought Aiko at Daz, then she should contact Daz for a refund because Daz  is offering Aiko free at the links you have posted."
My point exactly.  Although she doesn't NEED to buy the maps either, since there are a lot of free Aiko textures floating around, and even some V3 ones will work adequately with the figure.
DPH
ashley9803 ( ) posted Sun, 12 August 2007 at 1:33 AM
The version of Aiko I got when she was free, seems to have the morphs already loaded, ie. she morphs into other characters without having to load any extra head or body morphs.
I've never had to inject any morphs into her.
