Tue, Nov 26, 11:01 PM CST
Subject: Can't import material!
Insom_Nia ( ) posted Sat, 18 August 2007 at 6:40 AM · edited Tue, 26 November 2024 at 11:00 PM
Hello,
sorry if that sounds stupid but I'm puzzled.
I'm using Vue d'Esprit and downloaded a free Mat made also for Vue 5 d'Esprit.
www.microbion.co.uk/graphics/vue5.htm
But whenever I open the Material editor, browse to the new mat and try to open it
I get an error message: Unable to read this file
What is going on?
Thank you very much
bruno021 ( ) posted Sat, 18 August 2007 at 7:21 AM
No problem reading it here in Vue6. Mauybe it was done if Vue5Infinite, but I don't see why it wouldn't open in Esprit.
Insom_Nia ( ) posted Sat, 18 August 2007 at 7:44 AM
I just tried to import several other materials....the same...it can't read them.
Maybe it's something with the installation? Will re-install again....sigh
bruno021 ( ) posted Sat, 18 August 2007 at 7:52 AM
You say you're using Vue Esprit, but are you using the "real" version, or a demo? If a demo, maybe it's normal.
Just a thought.
spedler ( ) posted Sat, 18 August 2007 at 9:00 AM
Hi Insom_Nia,
That mat is one of mine - sorry you're having trouble with it. It was indeed created in V5I, but imports into my V6I, and like Bruno, I can't see why it wouldn't import into V6 Esprit. I don't have access to V6 Esprit, but I've tried it in V5 Esprit and it imports into that.
Steve
Insom_Nia ( ) posted Sat, 18 August 2007 at 9:30 AM
Congratulations for your fine mat....I REALLY want to use it!
But it seems to be a program error and nothing with your mat since
I tried to import different freebies and none would get past!
I use a full version and even as I re-installed again already it
didn't help.
Next stop e-on customer support I fear....
bruno021 ( ) posted Sat, 18 August 2007 at 10:19 AM
What is the built number of your Vue copy? It shows when you choose " about Vue6 Esprit" from the Help menu.
Insom_Nia ( ) posted Sat, 18 August 2007 at 11:00 AM
Also...it says:
Vue Esprit 5
Version 5.01-02
Build 272590
hmmmm.....
spedler ( ) posted Sat, 18 August 2007 at 11:06 AM
There's a newer build number for V5 Esprit. The one I have is build 283512, but I stopped using that version some time ago and there may well be a more recent build than that. Go to the e-on site and get the latest update, and maybe that will fix the problem.
Steve
bruno021 ( ) posted Sat, 18 August 2007 at 11:08 AM
Ok, you need to update your version to 5.11 built285692, this is the latest version for Vue5 Esprit.
Go to e-on's website and  download the update.
The freebies you downloaded were certainly created with a newer version than yours, which is why you can't read them ( no backwards compatibility)
Update your version, and you'll be able to have fun with your freebies.
Insom_Nia ( ) posted Sat, 18 August 2007 at 11:11 AM
THANK YOU!!!
I will do that immediately!!!!
runs
