Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Sep 29 9:12 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
First question:
Are you using any references at all? If not, you should. It would make some things easier to "see".
Have a look at Bay Raitt's site. He's got an animated gif showing how to do this from a cube. The layout would be similar using edge extrusion:
http://cube.phlatt.net/home/spiraloid/movies/movies.html
I think I wrote a brief tut on this somewhere but I don't have it on my PC anymore (HD failure). I'll search around.
Another place to look would be the Joan Of Arc tutorial at www.3dtotal.com in the tutorial section
Thanks. I'll check those out! And yes, I'm definately using backdrop photo references. :) I'm not a good enough artist to go even this far without them. But there seem to be certain sections where the photos don't help much, like behind the nostils. And the ear looks daunting. . One thing I thought of was whether maybe some people do the nose and ear seperately, unlike what I'm doing here, and then just join the verts?
Don't have much insight really, mostly thought I'd comisserate, that said...I HATE modeling noses! They get me every time. Ears, not so much of a problem, they have a nice flow to them for me, but noses always snare me. I'd rather model ten ears than one nose.
Best advice I can offer, is dig up a ton of wireframe images from other people, and see how they do it, and go from there. Find the flow that fits yours the best, and give that a try, maybe mix and match a couple different approaches if need be. Doesn't matter how you get there, as long as it looks good, and doesn't hurt the model any. It looks like you're off to a fair start so far.
As for modeling the part seprate, then attaching it, I find that works ok for the ears, b/c you can hide a lot of stuff around and behind them if need be. In fact I'm not sure I've ever modeled an ear attached, maybe on a low-poly model, but that's a whole different ballgame.
I think its best to model the nose in place tho so that it flows with the rest of the model. Its a lot harder to hide excess geometry right in the middle of the face, with all the deformation areas around, and not have problems.
Core i7 950@3.02GHz | 12GB Corsair Dominator Ram@1600mHz | 2GB Geforce GTX 660
Lightwave | Blender | Marmoset | GIMP | Krita
I started with the eyes, worked out a few loops around them. Then I went to the mouth, to get its location and shape nailed down, again, worked out a couple loops aroung it. Filled the nose in between the two, filled the cheeks in, then flushed out the chin and jawline. Did the ear seperate, patched it on, you can see some "extra" geometry around it becuase of that. Then I filled in the rest of the skull and started down the neck.
It seems like if you work too much detail into one area too early, you're bound to have trouble. Keep it as simple as you can, and add too it as you go if need be. I probably started both the eyes and the mouth with 8 or 12 [at the most] sided discs. That way as I worked on another area, and needed more geometry for it, I could easily just split a band of polys and make the appropriate adjustments, without being overwhelmed with a ton of extra geomtry.
Attached Link: Character Modeling (video tuts on Vertex Monkey)
Hi there,Nice to see another Modo user on Rendo.
There are lots of learning materials on modeling on the Lux site (have you seen their lates Luxology.TV section). Or you can get the needed stuff on the other great places for Modo resoursesv - "Vertex Monkey" site.
I added the link here to the section dedicated to the Character Modeling (one of the movies is for Nose modeling)
Cheers
slav
