Wed, Dec 4, 3:20 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: B&W from color
MGD ( ) posted Thu, 30 August 2007 at 4:30 PM · edited Wed, 04 December 2024 at 6:17 AM
In the thread, "Photoshop Vs Film question" started by **promiselamb**, I saw a hint from **Tanchelyn** that related to creating a B&W image.
That made me wonder what would happen to "Solitude", an image shot on
New Year's day in the Hamptons.
I did a quick trial with this result.
Martin
MGD ( ) posted Thu, 30 August 2007 at 4:31 PM
... and here's the original "Solitude".
Martin
TwoPynts ( ) posted Thu, 30 August 2007 at 4:40 PM
Both are great. Tough choice. Have you tried cropping out some of the foreground sand. Doing so would also give it a wider look.
zollster ( ) posted Thu, 30 August 2007 at 5:03 PM
the b&w version looks more dramatic  imo
MGD ( ) posted Thu, 30 August 2007 at 5:06 PM
I noticed that TwoPynts was wondering,
Part of what I have in this image is the sense of solitude ... almost isolation
of the subject -- he is right at the water's edge and IMO -more- sand rather
than less would increase that sense of isolation.
BTW, when I made test prints, the results didn't have the range of black
and white as what I can see on my monitor.
I need to think about what would improve how this image printed on my
Canon PIXMA IP-5000.  This printer has 5 ink tanks: CMYK, which are
dye based, and also a pigment black.
Martin
p.s. What did I learn today?  That I know a little less than I thought I did.
promiselamb ( ) posted Thu, 30 August 2007 at 6:47 PM
Ok I tryed Tanchelyn advice on black and white and I really like the results. I put it in my gallery because I am not sure if there is a button in here to choose nude. so younger kids dont see it. so i figured it might be safer in my gallery if you want to see my results of it :-)**
olivier158 ( ) posted Fri, 31 August 2007 at 1:57 AM
nice result ! and could be enhanced again  ;o)
Gog ( ) posted Fri, 31 August 2007 at 4:51 AM
Nice result, you could still afford to play with the contrast / curves a little further too!
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
Tanchelyn ( ) posted Fri, 31 August 2007 at 5:41 AM
I'm happy you are enthusiastic and get good results, but I did not invent this. I only learned it, so don't make me blush, ok?
Another thing you can do is convert to duotone. You can't access duotone in one movement though. First, after having played with- and got your greyscale image, you have to switch to greyscale mode( Image>Mode>greyscale) and then, in a second step, you can set to duotone (image>mode>duotone). Here you have the option to choose between duotone (two colours) tri- and quadtone (three and four colours) In fact these are created for printing on offset-presses, mainly to use ink / colours whose hues cannot be mixed with the basic cyan, magenta, yellow and black, but you can use them to your benefit. Even for internet display.
Choose for example duotone (tri and quad work the same, but with additional inks, so you simply repeat this for the other inks.).
In the dialog, you see "black" and an empty  rectangular space below it. Doubleclick there, and a dialog opens where you can choose a colour. This colour will be mixed with black. Choose one, and say  "wow" (necessary!). Try several untill you find what you really like.
Then you can doubleclick the small curve that's on the left of the colour in the duotone dialog. It will pop-up, and you can adjust like you fancy. Don't be afraid to try out some weird curves. You'll certainly be inspired.
When you get a result you like, switch back to rgb (image>mode>rgb)
This way, by choosing a second colour, you get a far more rich result. Because when you use only grey, your three channels, r,g, and b are identical. This reduces the possible hues. By choosing a second colour with a barely visible hue, not only you can get a result like old photographs, but you get different information in each channel, which leads to richer results.
and the cherry on the pie is that when you use four inks (quadtone) and you set your curves in special ways, you can get subtle hues depending on the lightness of the photo. "experiment" is the verb that applies here.
Now if this isn't fun!
There are no Borg. All resistance is fertile.
MGD ( ) posted Fri, 07 September 2007 at 1:30 PM
I read that Tanchelyn said,
I'm happy you are enthusiastic and get good results [converting color to
B/W], but I did not invent this. I only learned it, so don't make me blush, ok?
Thanks, your advice was quite good.
Did you learn that from a class, a book, or some other source?
Martin
Tanchelyn ( ) posted Fri, 07 September 2007 at 2:06 PM
I've done a lot of tutorials when I got photoshop 7 and asked questions on some photoshop forums. I also got Gary Bouton's Inside Photoshop 6, which was really cheap (because outdated) but he explains the basics very well. Also, I work as an offset-printer and do some occasional pre-press work, depending on the needs and the available personnel, so I got a practical foundation.
MGD ( ) posted Fri, 07 September 2007 at 3:04 PM · edited Fri, 07 September 2007 at 3:05 PM
My thanks to Tanchelyn who responded by saying,
You're right ... amazon.com has ...
Inside Photoshop 6 (9" x 7" x 2", 1320 pages) for $4.57 (+ S&H);
and Inside Photoshop 7 (9" x 7" x 2", 1056 pages) for $2.00 (+S&H).
Sounds like a bargain -- I'll get one
Martin
