Thu, Nov 14, 7:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Rendering
johnfields ( ) posted Fri, 31 August 2007 at 4:58 PM · edited Thu, 14 November 2024 at 7:50 AM
What do you all use for rendering? - I have poser 7 and I have seen work that is rendered with vue and other programs - I would like to know what the other options are out there. I am running a Pentium 4  3.00GHz,
3.01GHz with 1.96GB of RAM
this is according to the properties tab on My Computer - I'm really not that technically proficient with a computer. I find that I have trouble with the more detailed and intricate renders and I would like some thoughts on alternatives - money is an issue.
thefixer ( ) posted Fri, 31 August 2007 at 5:03 PM
I use Vue 6 Infinite for rendering, I generally set the scene up in Poser 6 or 7 then import to Vue for rendering because I prefer Vue's lights and render engine!
Injustice will be avenged.
Cofiwch Dryweryn.
Cheers ( ) posted Fri, 31 August 2007 at 5:08 PM
Set up in Poser 6 then into Vue 6 Infinite and Cinema 4D XL for rendering for me. I have also rendered some characters in Modo, but it always needs some texture fixes, but the render is fast and SSS looks great when applied.
Even though I usually use Vue for rendering (just a lot less hassle to import), I feel its worse of the three I use, just because the render speed is like a crippled snail when compared to C4D and Modo.
Twitter: Follow @the3dscene
johnfields ( ) posted Fri, 31 August 2007 at 5:20 PM
Fixer - how do you import - the whole scene and what format pz?
johnfields ( ) posted Fri, 31 August 2007 at 5:28 PM
Can you render a pz3 in VUE?
johnfields ( ) posted Fri, 31 August 2007 at 5:30 PM
or how about a .pmd in poser 7?
Cheers ( ) posted Fri, 31 August 2007 at 5:33 PM
PZ3 can be rendered in Vue, along with Poser materials. Characters and objects (with materials and animation) are usually only imported into Vue...camera and lights are not included.
johnfields ( ) posted Fri, 31 August 2007 at 5:44 PM
OK got it - thanks
FrankT ( ) posted Fri, 31 August 2007 at 6:43 PM
another vote for Vue 6 - infinite this time and I often use SkinVue if there is a figure in there.  I'd love Cinema 4D but I just can't afford it :(
My Freebies
Buy stuff on RedBubble
thefixer ( ) posted Sat, 01 September 2007 at 3:24 AM
Johnfields: Yes I import the whole Poser scene, characters, props, etc. with the Shader Tree option.
Bear in mind though, to do this I have a Mega pc, you couldn't do it with 2 Gig of RAM for instance.
You can import Poser stuff with that much RAM but Vue will make you work for it with it's memory issues which IMO it still has!!
Cofiwch Dryweryn.
drkfetyshnyghts ( ) posted Sat, 01 September 2007 at 12:30 PM
Do i detect a looking down upon the Poser 7 render capabilities?
drkfetyshnyghts ( ) posted Sat, 01 September 2007 at 12:41 PM
drkfetyshnyghts ( ) posted Sat, 01 September 2007 at 12:45 PM
oops!  No, i am just wondering if i am missing out on something by limiting myself to Poser7 renders.
D
madmaxh ( ) posted Sat, 01 September 2007 at 12:52 PM
Like TheFixer, I have also switched over to Vue for most renders, mainly because I wanted to do larger scale scenes with ecosystems and volumetric and spectral lighting. However, Poser's render engine is still very powerful, and with a little work can yield beautiful renders.
FrankT ( ) posted Sat, 01 September 2007 at 1:22 PM
Firefly isn't a bad render engine - I just find the lighting and GI/GR cababilities of Vue better for 90% of the things I want to do
My Freebies
johnfields ( ) posted Sat, 01 September 2007 at 8:15 PM
Here's a strange thing- when I try to render a complex scene at high resolution in poser 7 all I get is a blank grey screen WTH?
pjz99 ( ) posted Sun, 02 September 2007 at 1:13 AM
What exactly is in the scene?  Can you show a screenshot of preview (before rendering)?  It may be that the camera is outside a wall that in preview appears to be transparent, or something like that.
Also I recall that if you're using P7's external render, it can sometimes do something like that due to internet firewall settings (?)
My Freebies
