Forum Moderators: Staff
Poser reads the materials that are listed in the .obj file. Then writes them into the figure's .cr2 file. You can use the MAC version of UVmapper to change the name of the material easy enough. But you'll still have the old material in your list in Poser unless you manually remove it somehow. Us PC users use CR2edit for that. But you could open your .cr2 file with a text editor and remove the materials with that. ScottA
is anyone know that how can i delete the metarial list in poser or else let say when assign a knew metarial and if you wanna remove it what should have been done ? oh im using mac and poser 4 thanks
