Tue, Jan 21, 1:52 PM CST
Forum Moderators: Staff
Subject: External geometries a no-go =(
Darkworld ( ) posted Tue, 29 May 2001 at 2:41 PM · edited Wed, 08 January 2025 at 1:04 AM
well, Jeremy Keller from the online store has been helping me try to figure out how to text edit the CR2 file so that i can point to OBJ files externally. it all sounded neat and tidy, i mean simply replace all the vertex gobble-dee-guck with a handler and offset statement, make sure the pointer at the top points to the correct geometry. well... when i did that as per the instructions, it loaded fine, no errors... and this was all that was left of my figure (who is headed soon for the store) needless to say im not there yet... would greatly appreciate the missing piece of the puzzle hehe. All i did in this case was replace the geomcustoms for the HEAD, as it is the only part left not using my own geometry, it uses OBJ for the P4 male. I have to make it external for copyright reasons.
here it is
bloodsong ( ) posted Tue, 29 May 2001 at 5:26 PM
heyas; my guess would be that you copied the geomhandler thingy from the left leg parts to the right leg parts, but forgot to change the 'l' to an 'r' in the parts that are not visible. anyway, that's what i do sometimes, and that's what it comes out lookin' like. ;) if the obj pointers are pointing to your new custom obj, there's an extra trick you have to do to get it to read the head from the p4 male. i THINK you put the full path of the obj in the geomhandler part, but i'm not sure. jeff? scott? help!
Darkworld ( ) posted Tue, 29 May 2001 at 6:21 PM
well actually the legs should have nothing to do with it (hopefully), since i did not touch them in the cr2 editor. the head is the only part that needs to point to an external OBJ. and although it is pointing correctly, i have random loss of body parts (they are still there, just invisible) i mean... TONS of people are doing this, every single person who posts on DAZ3D has to know how, so it seems like there has got to be a cut and dried way to fix it.. argh
bloodsong ( ) posted Wed, 30 May 2001 at 9:01 AM
hmmm.... can you post the cr2 entry for the head? the one in the top section?
doozy ( ) posted Wed, 30 May 2001 at 7:52 PM
Did you delete the RSR after you made your change?
Darkworld ( ) posted Wed, 30 May 2001 at 7:59 PM
no... do you need to?
ScottA ( ) posted Thu, 31 May 2001 at 7:04 PM
Yes...any time you make changes you should delete the .rsr in the Geometries folder for that figure. I'm not sure I know what you are trying to do. But if you are getting invisible body parts. That means there are lines in the .cr2 file that don't match the .obj file it's looking for. If all you want to do is put an .obj pointer to a P4head. Then I think all you need to do is put this in your list of actors under the first .obj pointer heading: actor head:1 { geomCustom { numbVerts 0 numbTVerts 0 numbTSets 0 numbElems 0 numbSets 0 } storageOffset 0 0 0 objFileGeom 0 0 :Runtime:Geometries:P4NudeWoman:P4NudeWom.obj } Just replace your current geomCustom info with those lines. ScottA
Darkworld ( ) posted Thu, 31 May 2001 at 10:36 PM
yeah i think i got it now, thanks for the tips!!! what i was doing was deleting not just the head v, vt, and f info, but also like the right eye and some other stuff too lol. that file is so damn big i kept scrolling down too far every time i tried it, and ended up cutting extra.
bloodsong ( ) posted Fri, 01 June 2001 at 5:35 PM
heyas; er, scott.... how/why do you mix the geomcustom with the alternate obj pointer?? never seen that trick before :)
ScottA ( ) posted Fri, 01 June 2001 at 10:16 PM
This is the only way I know how to replace a body part by putting this info under the first pointer section Bloodsong. Is there another way to do it? I know how to switch body parts with a dial. But that's different and the alternate obj pointer goes under the second pointer section where the channels are. ScottA
Darkworld ( ) posted Fri, 01 June 2001 at 11:53 PM
hey speaking of that, how exactly do you make like a chair... that when you switch a dial it changes into a bench... something like that, i know it can be done ive seen it
bloodsong ( ) posted Sat, 02 June 2001 at 11:45 AM
heyas; i've never tried it, scott, so my impulse would be to skip the 'geom custom' parts and just put the storage and full obj pointer in. that doesnt work, huh? :) darkworld, that's geometry swapping; it uses codes swiped from the genital switch and poser 2 figure hands. there's files and info on that at the posertech egroup.
