Fri, Nov 22, 7:33 PM CST
Subject: How to save figure postion in P7?
AnAardvark ( ) posted Thu, 13 September 2007 at 3:08 PM · edited Fri, 22 November 2024 at 2:47 PM
Hi,
How does one save a figure position as part of a pose in P7? I think it was easier in P6, but there isn't anything which prompts me. I want to keep the translations and rotations as part of the pose.
thanks
raven ( ) posted Thu, 13 September 2007 at 3:52 PM
If you translate and rotate the figure using the Hip the placement should be kept in the pose. I'm pretty sure that Body translations aren't saved.
AnAardvark ( ) posted Thu, 13 September 2007 at 4:11 PM
OK, thanks. That's a big help.
SYNTRIFID ( ) posted Thu, 13 September 2007 at 5:19 PM · edited Thu, 13 September 2007 at 5:20 PM
When you go to save the pose, a window should come up asking you "Select additional information you want to save"  the tic box options will be "Morph Channels" and Body transformations"
Checking "Body transformations"  will save the current position of the figure in the saved Pose. "Morph channels" will save, well, morph channels, (body morphs, facial expressions etc)
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
Angelouscuitry ( ) posted Thu, 13 September 2007 at 5:34 PM
What SYNTRIFID said is correct, but for P7 only.
What Raven said is correct for previous version of Poser.  If you have the Hip selected, just before saving a Pose.PZ2(to the Pose library,) then any time you apply that pose your figure will be returned to those Pose Space Coordinates.
lesbentley ( ) posted Thu, 13 September 2007 at 5:47 PM
What Angelouscuitry said is mostly correct, except that it is irrelevant which part of the figure is selected when you save the pose.
Angelouscuitry ( ) posted Thu, 13 September 2007 at 5:58 PM
So is it that the Hip needs to be selected, when the pose is applied?
lonar ( ) posted Thu, 13 September 2007 at 10:50 PM
Doesn't matter what part of the character is selected before applying the pose in Poser 7 the pose will still work. As well lesbentley is correct about not having to have any specific body part selected before saving the pose it should be saved no problem, I usually do body just out of some unknown reason. :tongue2:
Angelouscuitry ( ) posted Fri, 14 September 2007 at 10:35 AM
Yeah, sure for P7, but it has'nt always been that way?
lesbentley ( ) posted Tue, 18 September 2007 at 6:46 PM
At very least from P4 on up.
