Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
You can navigate your browser in Carrara (have open the Content Tab) to anwhere you have content. Using the Add Folder pull-down menu on the Browser, select Add Runtime and it will load the runtime wherever you drive it to. In my case I have three runtimes: Poser, DAZ Studio, and Carrara. At some point I'll probably merge them all into one but for now, I have those three. At least on the Mac content installer, it actually added a runtime in the C6 folder. I might of directed it there myself (fragile mind that forgets things easily here) but I thought it did it automatically. Mark
just to confirm, the content installer has an option that asks the user for the location to install the c6pro runtime. in OS X, it's a vise installer that has "easy install" and "uninstall" options. under "easy install", the default location is the applications folder, but it also has a pull-down menu to "select folder", which would be the c6pro folder. as each new runtime is added to the c6pro content browser, it is assigned a name corresponding to the folder in which the new runtime is contained at time of addition.
What the best way to get all that new content from the content cd into C6. I was wishing for C6 to go find all the content like Daz Studio does.
