Tue, Nov 26, 1:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Butterflies behind bars - firefly rendering problem
Daio ( ) posted Mon, 17 September 2007 at 8:26 AM · edited Tue, 19 November 2024 at 3:27 PM
I'm having trouble getting a buterfly prop to render properly in P6 or P7. I've tried turning texture filturing on and off and checked the settings in the material room. This problem appears to happen in both P6 and P7 though the images below are from P6. Above is the preview.
"Do not meddle in the affairs of cats, for they are subtle and will piss on your computer." -- Bruce Graham
Daio ( ) posted Mon, 17 September 2007 at 8:27 AM
And the render. This the first time I've run into this problem and it has me a bit baffled.
Khai ( ) posted Mon, 17 September 2007 at 8:28 AM
on the wing textures make sure 'normals forward' is checked.
Daio ( ) posted Mon, 17 September 2007 at 8:40 AM
That fixed it. Thanks!
Acadia ( ) posted Mon, 17 September 2007 at 8:47 AM
Yes, I would try the normals forward.
I would also be tempted to try the tip from the following thread to see if it brightened up the wing colours a bit.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2965190&ebot_calc_page#message_2965190
Countach ( ) posted Mon, 17 September 2007 at 12:50 PM
This is what happens when Poser encounters a two-sided polygon.  Eliminating one side of each polygon ina a modelling program may also eliminate the problem.
