Sat, Jan 11, 9:21 AM CST
Subject: WIP-J'Quelinn, Texture Experiment
fiontar ( ) posted Tue, 29 May 2001 at 11:45 PM ยท edited Sat, 11 January 2025 at 9:18 AM
I've got to grab some zzz's, so I'll post this with out my usual set of caveats as to what I know is wrong or still needs work. So, for those who want to help out, just point out anything you like, don't like or stuff that looks like it may need to be tweaked or fixed. Of course, after I read it all, I can just say "Yep, I knew that", which in some cases will be true, but I promise I'll be appreciative. ;-) This is the Changing Fantasy Suit from DAZ, along with the texture pack by Symphony, once again from Daz. This is rendered in bryce and part of the fun is getting the right look with the textures outside of Poser. O.k., I'll point out one problem, the texture on the bracer doesn't seem to be mapping correctly. Haven't double checked to see if it's also messed up in Poser. Anyone have any thoughts on why? Anyway, please comment, praise and criticism both welcome and helpful suggestions most of all. :-) Fiontar
Ms_Outlaw ( ) posted Tue, 29 May 2001 at 11:53 PM
Looks very good to me. Can see I need some more lessons.
Lunaseas ( ) posted Wed, 30 May 2001 at 9:13 AM
Nice, especially the shield...have you tried to see what this would look like without the the gamma correction checked in the render options?
fiontar ( ) posted Wed, 30 May 2001 at 2:20 PM
Lunaseas, Actually, that IS with out gamma correction. :-) The first image, in the thread a few days ago, had gamma correction on. It's been a while since I worked on this stuff and couldn't figure out why everything was so washed out looking. Well, I figured out that it was the gamma correction, so I disabled it. This image is sunlight about 45 degrees above the horizon, supplemented with two, soft accent lights near the figure, one slightly redish and the other slightly bluish. Does it look washed out to you still? It looks good here. I notice that a lot of Mac images look too dark on my PC, so if you are on a Mac, maybe that's why you thought is was gamma correction on?
fiontar ( ) posted Wed, 30 May 2001 at 2:56 PM
A problem with the character is the strange bulge on the upper arm where it joins with the shoulder. I took a quick look in poser and there aren't any morph settings applied for the uper arms or the collars, so I'm guessing it was a full body morph that didn't apply to the arms for some reason. So, I'll have to save the face morphs, redo the body and readjust the clothing, unless I can figure out which morph caused it. It may not be immediately noticable here, but from the side, it's a very noticable flare. :-( I think I'll try to iron out the textures before I get into that... As to the textures, looking at it today, I think the skin texture might have the ambient set to high, notice how much darker the unlit side of the skirt is than the unlit flesh. I'll have to see if I can lower the Ambient, but compensate for a similar skin tone in the lit area. For those thinking this looks a lot different than the same textures on their set, Bryce, first of all, makes a huge difference over pure Poser rendering. With tweaking for lighting and texture properties, I am always amazed at how good the renderer is for such a reasonably priced package. Also, the texture settings are not left at the defaults that poser would export. Once the image texture is applied to the item, I fiddle with the other settings to get the desired look, some areas have some reflectivity, metallicity, etc... along with slight bump mapping using the alpha channel for the image texture. If I get really insane with the details, I'll even make some reflectivity and metallicity maps from the textures so the gold on the skirt looks more metalic. I actually dreamed textures last night. ;-)
