Mon, Feb 3, 4:52 PM CST
Subject: Help needed with lights
simontemplar ( ) posted Thu, 20 September 2007 at 3:24 PM · edited Mon, 03 February 2025 at 4:52 PM
Hi there ^^
I am trying to render a scene which includes an unimesh figure sitting ona  desert island near a campfire. Since all there is around is the sea and the sky, no real decorum problem there... except that I don't want the yellowish light of my fire to turn my skydome yellow. How can I make it so the skydome does not react to this specific set of lights?
Thanks in advance, I am clueless here.
ockham ( ) posted Thu, 20 September 2007 at 3:35 PM
If the fire is an actual light, you could make it a point light and set its
Dist Start and Dist End so that the light fades just beyond the figures...
If it's an ambient, I don't know!
My python page
My ShareCG freebies
simontemplar ( ) posted Thu, 20 September 2007 at 3:51 PM
actually they're spots. I purchased the "ultimate" fire kit from romanceworks today :-)
jonthecelt ( ) posted Thu, 20 September 2007 at 4:25 PM
If spots, then you can do a similar thing - just set the distance start to a point beyond the figure, but before the skydome. To help matters, it might be worth scaling up the skydome as well to give you more room to play with.
JonTheCelt
simontemplar ( ) posted Thu, 20 September 2007 at 4:32 PM
thanks for the tips :) I'll try that in the morning :D
These fire effects are nice, too... just a bit to fiery :p
bagginsbill ( ) posted Fri, 21 September 2007 at 10:02 AM
Sky domes give off their own light. You should not plug your sky color map into Diffuse_Color. Set DIffuse_Value = 0, Specular_Value = 0, and plug the color map straight into Alternate_Diffuse.
The sky will now have NO reaction to light of any kind. Even if you delete all your lights, it will still be there.
simontemplar ( ) posted Fri, 21 September 2007 at 6:27 PM
Great tip, Bagginsbill, thanks a lot. That's exaclty what I was looking for. :)
melikia ( ) posted Mon, 24 September 2007 at 1:02 PM
holy chit, bagginsbill!
what a DIFFERENCE in my skydome!  thank you!!!!!!!!!!!!!!!!!!!!!!
Rarer than a hairy egg and madder than a box of frogs....
< o > < o >    You've been VUED!    < o > < o >
         O                                                    O
bagginsbill ( ) posted Mon, 24 September 2007 at 2:28 PM
That was an easy one, eh?
