Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Have you contacted e-on technical support?
LVS - Where Learning is Fun!
One thing is - if you have not done that already - to switch off automatic keyframing.
I son't think that the spanish os is the problem, a lot of what you describe sounds more like a graphic card issue. Maybe you try to switch Vue to wireframe mode in the preferences and see wether it makes a difference.
Hi, im having issues when creating lights in animations, an unwanted keyframe shows up when i click on POWER in any place on the timeline. And when i select it i can see old vue 5 icons appear on the viewport. I can't delete this keyframe.
I also have problems when trying to move a keyframe, it's not seamless but a little choppy. I've seen also some timeline bugs, like for example half a keyframe show up and i can't delete it, and sometime the timeline navigator dissapears.
I thought there was something wrong with my vue version so after several uninstallations and reinstallations i decided to install vue 6.5 PLE to see if it worked ok and i'm having the same issues with PLE too.
I'm using Windows XP SP2, i've already made an OS clean installation and i keep having the same issues. My OS is in spanish, could this be the problem?
