Sat, Jan 11, 9:25 AM CST
Subject: Anyone running Poser in limited account?
chinnei ( ) posted Wed, 03 October 2007 at 5:04 PM · edited Sat, 11 January 2025 at 4:29 AM
Ok, so here's my setup, I've created 2 accounts in my XP Pro, one administrator and one limited account.  I have Poser 7 installed in E: drive along with rest of my runtimes.  I can run Poser 7 in administrator account but it seems I can't in limited as it crashes on load.  I could run it in limited account but only by using a trick that pretty much tells it to run as an administrator.
So, is this true that Poser 7 can't be used in limited accout as a limited user? Or what if I create an exception in security setting and give Poser a full control, could that work?
BeyondVR ( ) posted Wed, 03 October 2007 at 6:43 PM
I'm not really familiar with the intricasies of a non-admin account, but one thing that springs to mind is that Poser does a check to see if another instance of the same serial number is running on a network.  Maybe that action is being blocked on this account, and crashing the app.
You may get a quicker answer to your problem from e-frontier.
John
chinnei ( ) posted Wed, 03 October 2007 at 7:44 PM
yeah it must be using other administrator resource besides itself.  I gave entire directory an administrator right but it still wouldn't run in limited account.
I'll contact EF and see what they say about it.  Hopefully there's a way around this.
Thanks.
pjz99 ( ) posted Wed, 03 October 2007 at 7:59 PM · edited Wed, 03 October 2007 at 8:00 PM
Poser makes use of the registry, which I don't expect your limited account is permitted to do (read or write I'm not sure).
My Freebies
Dizzi ( ) posted Thu, 04 October 2007 at 3:44 AM
It works fine with a non admin account for me. I'd try to run an utility like filemon to see if there are some file system based access issues.
Neuer_Versuch ( ) posted Thu, 04 October 2007 at 5:31 AM
Yes, I also use a non admin acount without any problem.
I work so with all Poser-versions from 3 to 7.
I think you have a other problem on your PC with your account.
pjz: XP can use with all accounts the registry on a running program - this would not be also absolutely senseless if so would be.
chinnei ( ) posted Thu, 04 October 2007 at 7:28 AM
hmmm, I see.  So it can be used in limited account.  How is your Poser installed?  Is it installed in main drive, and if it is, are you using any external runtimes?
As far as using Poser in non-admin, do you have full control of files, like modifying and saving it, or did you have to issue an administratror right in order use the files?
Penguinisto ( ) posted Thu, 04 October 2007 at 8:44 AM
I think PJ was referring to the fact that you cannot edit the registry (regedt32.exe) unless you have administrative rights on the machine, which is correct. Most default XP installs allow the first user account full administrative rights. The funny thing is, OSX just installs Poser (*nix has no 'registry' - IMHO a good thing), and since its libraries are local, you don't need sudo/root (the password-entering blurb you see) to install it there. (OSX has a whole different security model, which works very well). /P
