Thu, Jan 23, 4:41 PM CST
Subject: need help
thee coop ( ) posted Thu, 31 May 2001 at 8:53 PM ยท edited Thu, 23 January 2025 at 4:39 PM
I am looking for extensive help on making a texture from a object with multiple parts. I am using uv mapper but when it seperates it isn't giving me the results I need to paint any help is appriciated.
wyrwulf ( ) posted Thu, 31 May 2001 at 8:55 PM
I hope your machine is in groups. You need to select by group in UVMapper and map them separately. To start, I would probably tile by group, then go from there.
thee coop ( ) posted Thu, 31 May 2001 at 9:00 PM
I've done that and shows up in 500 little pieces that i can't tell what's what
wyrwulf ( ) posted Thu, 31 May 2001 at 10:47 PM
Did you name the groups or are they all default#? You might need to go back into Rhino and name the groups so you can tell what they are.
dwilmes ( ) posted Fri, 01 June 2001 at 6:57 AM
That is some impressive model, sure hope you can get it Poserized! One question: it appears to have a boiler and whistle, but hydraulic cylinders. Steam excavators were always cable machines, of course. If that IS a boiler, it needs to be bigger, with a stack. A lot of work in that carriage, and it gives you the basis for a bulldozer, a tank, anything with treads -- great job! Dan http://www.neca.com/~dwilmes/cr2edit.html Sorry Win only for software http://www.zenwareonline.com for ZenPaint, ZenTile, ZenGrid and VueMaster
Cybermonk ( ) posted Fri, 01 June 2001 at 8:40 AM
I just discovered this trick myself. Import your object into Poser first then select it. Now click on the grouping tool. Now select each sub objet and assign it a texture name you will recognize. Export it being sure to preserve part names in the option box. Now you can select by material in UVmapper and you'll know what your looking at. Man this has made it so much easier for me. Hope this helps
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Cybermonk ( ) posted Fri, 01 June 2001 at 8:48 AM
oh yeah if your using Rhino it makes a flat weird looking uvmap. So be sure to pick a new map(under edit in uvmapper), like planar or box. I usually pick one and do the whole thing first. Then tile this and then select each group and experiment with what works best on the indiviual parts.
Albert Einstein
