Thu, Nov 28, 7:26 PM CST
Subject: Round disk for cloth room?
BecSchm ( ) posted Mon, 08 October 2007 at 10:35 PM · edited Thu, 28 November 2024 at 2:36 AM
Is there a round flat primitive available any where for the cloth room?  The square one that comes with Poser doesn't work very well for skirts.  I tried to make my own round object in Autocad, and it works, sort of.  As you can see, it renders funny; something to do with the polygons in the model, I presume.  Is there any way to fix that?  OR is there a round shape already out there somewhere that I can get?
Apologies if this has been asked before!
stewer ( ) posted Mon, 08 October 2007 at 11:08 PM
Attached Link: http://www.poserfashion.net/tablecloth.htm
Here's a table cloth.
BecSchm ( ) posted Mon, 08 October 2007 at 11:10 PM
Thanks!   Just what I needed!
ockham ( ) posted Mon, 08 October 2007 at 11:15 PM
Attached Link: http://ockhamsbungalow.com/MiscProps/Skirt-flat.zip
This might or might not be better than the one you've got....
It's UV-mapped cylindrically so that weaves will look right, I think......
My python page
My ShareCG freebies
BecSchm ( ) posted Mon, 08 October 2007 at 11:30 PM
These both work great - thanks for the links -
Lucifer_The_Dark ( ) posted Tue, 09 October 2007 at 5:35 AM
You could also use the High res ball prop included in poser, just change the z scale to 1 or 2 & you have your round disk :D
Windows 7 64Bit
Poser Pro 2010 SR1
EnglishBob ( ) posted Tue, 09 October 2007 at 6:34 AM
Quote - You could also use the High res ball prop included in poser, just change the z scale to 1 or 2 & you have your round disk :D
This probably won't work very well, unfortunately. The cloth room doesn't like double sided meshes.
SamTherapy ( ) posted Tue, 09 October 2007 at 8:23 AM
You could, however, use the Grouping tool to create a prop from one end of a cylinder.
EnglishBob ( ) posted Tue, 09 October 2007 at 8:48 AM
...but not the Poser prop cylinder, which has too few facets to work convincingly in the cloth room...
SamTherapy ( ) posted Tue, 09 October 2007 at 9:40 AM
Yeah, you're right there.  I'm used to creating primitives in UVM Pro these days.  I forgot about the naff ones in Poser.
