Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Given that it's a flattened image with no alpha mask whatsoever, there's no "transparency" to select.
If it were layered, and one of the layers semi-transparent, then there you go, but it's flat.
I was thinking the same thing as spedler - I'd just recreate it given how simple it is, and make the grey box semi-transparent so you can see what's underneath.
I know you were looking for something better as far as instructions or help, sorry. Good luck-
-Lew ;-)
ok not sure i understand you correctly but here goes,
( i did this with you second image, but will also work with your first)
take you image into photoshop, then duplicate layer in the layer panel (you need to do this to be able to activate the layer style options), hide the underlying layer (make non- visible) and select the duplicate layer,
then click "layer" (drop down-menu) then select "layer style", then "blending options...",
now you have your layer style popup window, at the bottom you'll see two sliders, one says "this layer" it has a black end slider and a white end slider, if you click and drag on the white end slider from right to left (doesn't have to move very much at all),
you will now have no white visible, and be left with a transparent background replacing that which was white, save that as a .png, problem solved, you now have a transparent image again.
(puts super-hero cape back on, and assumes his heroic pose, again Vince has saved the day, starts to mumble something about he doesn't do it for the fame but for his fellow... blah, blah)
My knowledge of photoshop isn't bad. Though I'm not an expert (yet?). This particular issue has me a bit stumped. I'm familiar with alpha channels, but not sure how to get a partially transparent object from a solid background.
I want to get a picture with it's transparency preserved. but I can't get it directly. The best I can do is take a screenshot of it on a colored background. Cutting it out would be pretty easy, but that alone wouldn't preserve it's transparency.
The particular image is this:
[IMG]http://i103.photobucket.com/albums/m143/WarKirby/nametag.png[/IMG]
it's a nametag, partially transparent. Shown with a white background, but I can get a different color if it would make things easier. I need a way to filter out the white background, and get the nametag on a transparent background. Any advice?
