Thu, Jan 23, 11:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: can you make piston ?
smalll ( ) posted Thu, 25 October 2007 at 8:00 PM · edited Thu, 23 January 2025 at 11:56 PM
Hi.
I want to know how can I make piston that can use in poser.
I need your help.
If you know it, please teach me.
You can download file in http://www.bokgi.net/test/piston.zip
Please...
Gareee ( ) posted Thu, 25 October 2007 at 8:15 PM
If you really want to learn how to rig something like that, pick up the posr content developement book, "Secrets to poser figure creation" by BL render.. she actually covers exactly how to rig up a piston assembly in one chapter.
It's available at Amazon.
Khai ( ) posted Thu, 25 October 2007 at 8:34 PM
lesbentley ( ) posted Fri, 26 October 2007 at 5:21 AM
I downloaded the piston.zip, and extracted the test.obj, but the test.obj will not import into Poser.
geep ( ) posted Fri, 26 October 2007 at 8:28 AM
*(click image to view full size)*
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 26 October 2007 at 9:08 AM
*(click image to view full size) * ... or maybe this? ............ Does that help?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 26 October 2007 at 9:20 AM
Hi smalll,
It appears that your object file contained in the zip file, e.g., http://www.bokgi.net/test/piston.zip, is not in the standard Wavefront OBJect file format.  It appears to be a special "Rhino" format.  I do not have Rhino so I can not help you.
Sorry ... ;=[
cheers, (anyway)
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
nruddock ( ) posted Fri, 26 October 2007 at 12:44 PM
To be able to work with the OBJ file in Poser, you'll need to use whatever the Rhino command(s) are to turn it from a set of NURBS into a polygon mesh.
You'll also need to make sure that the seperate parts are properly transformed into groups when exporting.
