Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 4:15 am)
**YAY !!!
We have a WINNER !!!
Congratulations Liz !
NaySayGuy will select a prize just for you.
And now, a question for all of you ...
If you don't have Carrara but would like to find out how to make your own models using only Poser ...
Stay tuned ...
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I will pass the prize onto my partner, talisman018, for answering that. Got her Carrara 5 and 6 to do some modeling and maybe morphing for Poser.....but, she, ummm, well, hates Carrara. Loves Amapi instead.
Weapons of choice:
Quote - I will pass the prize onto my partner, talisman018, for answering that. Got her Carrara 5 and 6 to do some modeling and maybe morphing for Poser.....but, she, ummm, well, hates Carrara. Loves Amapi instead.
Amapi ??? ...... Isn't that used for making maps? ... ;=]
Anywho ...
Thanks to all those who participated and better luck next time.
For the WINNER :
**Please email da naysayguy@cableone to see what you have won.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Oooooh! I don't know the answer to this, but is this maybe the beginnings of a Dr. Geep Carrara course?
It was only maybe a little over two years ago when I first opened Poser, clicked around a bit and sadly closed the program. I wanted to make things with it, but didn't have a clue what the buttons were for or what to do with it after saving for months to buy it. Then along came Dr. Geep and the Naysay guy and all the others and the secrets were revealed!
I sit here now with Carrara 6 Standard, the import plug-in and---I open it up, click around and close it back up again because even though I know this program does awesome things I have no idea where to begin. Is it even thinkable that Dr. Geep once again will come to the rescue? Is there hope??? I know, I know...there's the PDF manual thing in the program but when you don't know the first thing about it or where to begin it is not much help.
FYI -
Ok, well, NaySayGuy says he has not received an email from the winner so I will post the info here.
The winner, Latexluv, has requested that the prize ...
(a $10 Gift Certificate redeemable here at R'osity)
... be awarded to talisman018 and that has been done.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Quote - > Quote - Is it even thinkable that Dr. Geep once again will come to the rescue?
Bob struggles in the close confines of the phone booth, desperately trying to put on his cape and suit...but years have passed and his suit seems to be a tighter fit than before!
:lol:
@ DarkEdge .................. :lol:
Thanks for the chuckle but you don't know how close to the truth you have come, i.e., tighter fit than before.*
cheers,
dr geep
*P.S. No offense taken ... it takes alot more than that to get to me.
Please keep the comments comin' ... that's what "makes" this place fun, n'est pas? ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
@ yukonjak
*"Oooooh! I don't know the answer to this, but is this maybe the beginnings of a Dr. Geep Carrara course? ..."
*Perhaps so ... you might want to stay tuned and check Dr Geep Studios for some info ...
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
The working box in Carrara is excellent. Besides the ground you get two sides of the rest of a cube, in grid form. When you place objects in the box you see a "fake shadow" of the item against the back and side wall, much as you see a fake ground shadow in Poser. This is a helper in keeping things oriented and located. You can tell the scale and height of things.
You can easily change the size of the walls, like you can scale up or down the ground in Poser
I find that when you start flying around with the camera, having the working box walls as well as a ground really helps you stay oriented.
::::: Opera :::::
Thanks Opera ... ;=]
The Working Box* in Carrara(5) can be used to accurately position objects with each other and, also, accurately adjust the size/scale of an object or figure.
cheers,
dr geep
**Now ...
**Would you like to know how to make a "Working Box" for use in Poser using only Poser to make the working box?
cheers,
dr geep ... :o]
edited 10/5/2019
Dr. Geep might be teaching a Carrara course? Excellent.
I would like to see what NaySayGuy would do with Poser Pro..........especially if he got to use it in conjunction with Lightwave, 3DS Max, or C4D. :sneaky:
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2721469&page=1
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Hi SSAfam1,
Yes, if you export it from Carrara as an object (.obj) file ... why not. ... ;=]
Then just Import the Wavefront OBJect file into Poser.
And, that's all there is to it.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
A working box!!!!!!
Now what do we win?????????? :laugh:
Weapons of choice:
