Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
I think you're confusing file formats. A prop is nothing more than a mesh saved into Poser's library. Poser will then automatically change it to .pp2 file. A .cr2 file is the file that contains all of the properties of a Poser Figure. All of the bending, morphs, material info, etc. is located in them. Only Poser can create a .cr2 file through the process of converting a mesh into a poseable figure. ScottA
interested in making my own props. Can you suggest books or tutorials? All of the books I've seen, (and I work in a bookstore) are pretty lame and none discuss prop creation at all Thanks
