Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2717864
> Quote - Anyone know what this means?See attached link.
Other info and a link to the original thread at DAZ -> here
Quote - Any scene I use her in seems to save OK. But when I try to re-open afterwards, whole scene won't load at all
Did you look at the Renderosity thread linked in my previous post ?
If you've turned off the "Use external binary morph targets" option, you should be able to reopen scenes saved after you turned it off.
Scene saved before you turned it off need to be recovered.
You could try redownloading/reinstalling V4.1as I believe the problem has been fixed (I would still recommend turning off the mentioned option for P7, for P6 you have no choice).
Whenever I save a Victoria 4.1 character file (on Win XP system with 2 Gigs of memory), I get a popup window saying "An error occured while processing morph delta data. There may be insufficient memory to process data or the PMD file is invalid".
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
