Sun, Jan 5, 3:33 AM CST
Subject: Problem Saving Victoria 4.1
Terry Mitchell ( ) posted Fri, 02 November 2007 at 3:29 PM · edited Mon, 25 November 2024 at 1:54 PM
Whenever I save a Victoria 4.1 character file (on Win XP system with 2 Gigs of memory), I get a popup window saying "An error occured while processing morph delta data.  There may be insufficient memory to process data or the PMD file is invalid".
Anyone know what this means?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
nruddock ( ) posted Fri, 02 November 2007 at 4:35 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2717864
> Quote - Anyone know what this means?
See attached link.
Other info and a link to the original thread at DAZ -> here
freyfaxi ( ) posted Sat, 03 November 2007 at 2:40 PM
I don't know whats wrong with V4.1 on  my win xp system :( Any scene I use her in seems to save OK. But when I try to re-open afterwards, whole scene won't load at all :( I've virtually given up on V4.1 :(
nruddock ( ) posted Sat, 03 November 2007 at 3:55 PM
Quote - Any scene I use her in seems to save OK. But when I try to re-open afterwards, whole scene won't load at all
Did you look at the Renderosity thread linked in my previous post ?
If you've turned off the "Use external binary morph targets" option, you should be able to reopen scenes saved after you turned it off.
Scene saved before you turned it off need to be recovered.
You could try redownloading/reinstalling V4.1as I believe the problem has been fixed (I would still recommend turning off the mentioned option for P7, for P6 you have no choice).
freyfaxi ( ) posted Sun, 04 November 2007 at 5:05 AM
"I'll give that a try..see if it makes a difference :)
