Sat, Nov 23, 9:48 PM CST
Subject: Tweaking SmartPropped props
FrankT ( ) posted Sun, 04 November 2007 at 5:57 PM · edited Sat, 23 November 2024 at 9:33 PM
Suppose I have a sword for e.g. that is a smart prop, parented to V3s right hand.  Is it possible to modify it somehow so that it's smart propped to V4s right hand ?
If it's doable, can it be done directly in Poser or do I have to modify the PP2 file ?
Regards
Frank
My Freebies
Buy stuff on RedBubble
ockham ( ) posted Sun, 04 November 2007 at 6:02 PM
If you're using the same hand, you'll probably have to do it
in Poser, because that's the only way to see the adjustment.
Simply load the prop, adjust to the new figure, then resave,
preferably with a new name.  As with any smart prop, when
Poser asks the question about selecting a subset, say No!
My python page
My ShareCG freebies
FrankT ( ) posted Sun, 04 November 2007 at 6:09 PM
Ooo right.  I'll give it a go then
Ta muchly
My Freebies
BeyondVR ( ) posted Sun, 04 November 2007 at 9:49 PM
You'll probably need to unparent it - Object--Change parent--choose Universe - then set parent again after you adjust it.  Poser won't ask about a subset; that's just an option.  It will ask if you want to save as Smart Prop.  Say yes to that.
John
FrankT ( ) posted Mon, 05 November 2007 at 6:38 AM
I had a bit of a play with it and it seems to work pretty well - yet another tip to add to my ever growing list of cool things to do in Poser when I'm bored
Thanks peeps
My Freebies
