Wed, Oct 2, 11:32 PM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Merging Animation Layers in Poser 7?
kuroyume0161 ( ) posted Tue, 06 November 2007 at 10:36 PM · edited Wed, 02 October 2024 at 9:36 PM
I'm here appealing to the Poser Python illumanti on the possibility of using this to merge animation layers into the base layer.  From a cursory examination of the Poser Python documentation this doesn't seem possible, but it would be edifying to have a final word from those who know better.
Thanks!
 -- Bjarne Stroustrup
markschum ( ) posted Wed, 07 November 2007 at 12:40 PM
I dont think it would be too difficult , its just moving the keyframe data from one layer to another.
I will have a look at it for you  :)    , doesnt poser have a "merge down"   feature , or a cut and paste ?
markschum ( ) posted Wed, 07 November 2007 at 3:31 PM
I finally managed to have a look at my Poser system and sadly there doesnt appear to be a python method to change between animation layers :unsure:  nor does there seem to be a merge command .  :sad:
If you save an animated pose set and save the layers , when you load it , it gives an option to merge layers and apply them to the base layer .
kuroyume0161 ( ) posted Wed, 07 November 2007 at 3:49 PM
That's interesting.  When you say 'animted pose set' you mean a pose containing the animation into the Pose library, correct?
This would do exactly what the person is requiring - merge layers to the base layer.
markschum ( ) posted Wed, 07 November 2007 at 10:34 PM
yes , a pose saved to the pose library , and selecting to save the frames .
When loading the pose you get an option to merge layers to a specified layer .
kuroyume0161 ( ) posted Wed, 07 November 2007 at 11:34 PM
Thank you very much for the clarification. :)
