Fri, Jan 3, 6:26 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 29 10:47 pm)
Carrara Free Stuff here.
Subject: Boat wake on water?
rfornasari ( ) posted Tue, 30 October 2001 at 6:43 PM ยท edited Tue, 31 December 2024 at 10:25 PM
Anybody have any idea on how to do the wake of a boat on water? I'm scratching my brain without too much success.
I've thought of a texture, a "wake object", and some sort of behaviour. Unfortunately I'm new at 3D and Carrara so skills need developemnt.
Does anyone know of a site with a water tutorial?
Be grateful for any ideas.
litst ( ) posted Tue, 30 October 2001 at 7:37 PM
Attached Link: http://www.chez.com/litst/eng/tutorials.htm
Hi Rfornasari and welcome to the 3D world, Actually, i've made a tutorial about shading a calm sea in Carrara with the Water:Waves function . It's on my site, on the link attached . It's available in english and in french . For the wake, i think there's a way to add a rectangular layer on the water, with a custom-made texture with the wake waves on it . Mix the layer with the bump of the water and move the layer as you animate the boat . Not sure what would be the best way to mix the layer, though ... I'll make some tries . If you want some foam, then you can add an extra object with an animated shader . Tough one, kinda challenging :) I'll make some tries and come back if i end with something interresting . litst
litst ( ) posted Tue, 30 October 2001 at 8:51 PM
I think i got something there ... I'll post the shader tree .
litst ( ) posted Tue, 30 October 2001 at 9:03 PM
See how i've done this ? First i've added a rectangular layer to the original bump channel . Then i've put my (bad!) wake texture in the layer . And that's it ! With this technique, you can animate the wake by putting a movie instead of the texture, and make the wake follow your boat by changing the layer's coordinates . Just a tip : you won't be able to add the layer to the bump channel directly from the menus . So first, add a parametric mapping and add the layer to it . Then if you want, drag the layer on top of the parametric mapping . Carrara will tell you that you can't put the layer here, but if you force the drop, it should work okay anyway . That's just a way to do it, there are surely others, but i hope it will help you and give you some ideas ! litst
rfornasari ( ) posted Wed, 31 October 2001 at 7:58 PM
Thanks litst! The water tutorial and your solution are very impressive! Not sure I understand the ins and outs of your explanation but I'll get there by playing around with it. Thanks again.
mhscspo ( ) posted Wed, 14 November 2007 at 4:44 PM
The link doesn't work I'm still in the dark on this one..
bwtr ( ) posted Wed, 14 November 2007 at 7:59 PM
Litst, sorry, I can not get a download from that link either. Are you the Litst with that old Carrara making a body/head tutes---which EVERYONE still needs to learn from?
Adding the DCG Terrain Tool to you idea could be good also.
bwtr
Mhawke ( ) posted Thu, 15 November 2007 at 1:31 PM
Quote - The link doesn't work I'm still in the dark on this one..
The post is 6 years old ... link probably went dead years ago.
Miss Nancy ( ) posted Thu, 15 November 2007 at 1:56 PM
litst's site is no longer active. he was working for one of the prior owners of ray dream/carrara, possibly metacreations.
menschtx ( ) posted Sun, 23 December 2007 at 3:30 PM
Hello Nancy, how do convert your site to English?
Michael
