I seem to recall there being some tutorials about the probe light node by someone (Relik, I think? ) over at RDNA. He goes into a lot of detail on what the various paramteres of the probelight node do, and what they mean.
In a nutshell, each of the various settings marked 'value' refers to a different direction the light can come from - the 'value' in question is the RGB value of light from that direction. What you need to do - and I recommend finding those tutorials to check which value you need to change it to - is to turn of the 'light' coming from the bottom, and find the setting which controls 'light' from the left. you don't actually need to rotate anything at all.
JonTheCelt
Much better is to use a setup like this. I put a spot light in position with each light panel. The panels and wall do not cast shadows. Each light has a cone from 50 to 160 degrees.
I used raytraced shadows on them, with 5 pixel blur.
Note I hid the wall here so you could see the spotlights.
Render coming next.
For more realism, use more lights - perhaps three for each panel.
From this angle it's kind of obvious that the spot lights are only in a low position. It would be better with 10 lights, where each panel has two, high and low.
I would like rotate one node but i don't know how ...
My sphere have a probelight node ( first picture )who the light is configured to come from the bottom ( floor on the second picture ), i would like she come from the left ( wall on the third picture ) without recalculate all the parameters in the probelight ... How to ? ( I hope you understand ... )
thx
Génération mobiles Le Forum / Le Site
