Tue, Feb 11, 7:36 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
Carrara Free Stuff here.
Subject: Arrrrrrrrrgghhhh!!!!!!!!!!!
RLG1034 ( ) posted Fri, 01 June 2001 at 3:54 PM · edited Thu, 23 January 2025 at 4:28 AM
From this rather simple question you will be able to tell I just got Raydream, and that it is testing the limits of my sanity. All I want to do is create a simple pyramid. And if anyone can tell me why they could'nt include one in the primatives pallet.
MarkBremmer ( ) posted Fri, 01 June 2001 at 6:07 PM
Just start out with a square in the Free Form modeler. Then select symmetrical as shown in the image above. Finally, use the arrow tool and select the end point of the envelope and drag it towards the center line/extrusion path. 3D modeling is absolutely the most counterintuitive thing that I've ever done. But once you get the hang of it, it's a blast! Good luck!
twillis ( ) posted Fri, 01 June 2001 at 6:08 PM
Would a vertex cube work? I mean, start with a cube, then weld the top four verticies together (I'm in Carrara, not sure if RayDream has the same sort of vertex modeller). --Terri
smcquinn ( ) posted Fri, 01 June 2001 at 9:39 PM
Yes, the Carrara VM method works better, I think. The spline pyramid is tricky at the peak, but the VM peak is a single point. Use a layers list of flat shaders applied to each of the faces. SMcQ
willf ( ) posted Fri, 01 June 2001 at 10:34 PM
The other option is to start with the SplineModeler as Mark suggested. Instead of the envelope create another cross section at the end in order to make the tip. Select the end cross section & scale it to .1% (don't use 0). That's the fun part, many ways to skin the cat.
RLG1034 ( ) posted Sat, 02 June 2001 at 5:21 PM
Thanks all. Your right willf all of these ways worked with great results. Makes me feel pretty bad when I could'nt even stumble on one of them on my own. Oh well guess I'll just have to keep plugging away at it. Thanks again. :))
willf ( ) posted Sat, 02 June 2001 at 10:25 PM
No need to feel bad, working in 3D is quite odd at first. Funny, we live & work in a 3D world but when going from 2d to 3d art it is hard to orient yourself to the working space. Just ask-away, you will almost always get some help (unless nobody else knows either!).
AzChip ( ) posted Mon, 04 June 2001 at 12:37 PM
One other tip -- when you're building a pyramid in the free-form modeler using Mark's technique, be sure to set the grid to "snap to," that'll make sure the point of the pyramid is a single point.... And keep on asking; that's what the forum is here for!
twillis ( ) posted Mon, 04 June 2001 at 1:05 PM
That, and sharing our favorite cheddar cheese recipes. Actually, I like these kinds of questions. It's really neat seeing all the different approaches. Do you suppose one could make a pyramid as a formula object? I was playing with simulating pyramid bricks ausing a formula shader a couple of months ago, but the object itself was a vertex object.
twillis ( ) posted Mon, 04 June 2001 at 1:25 PM
Here's my pyramid with my formula shader experiment (not really right along the edges). This is the formula I used for the Blender channel under Color, which was also copied under the Bump channel, in case anyone wants to play with it. w=5; h=5; b=5; g=0.1; r=b*2+1; d=h/r; e=w/(b+0.5); f=(z/d)-floor(z/d); j=(f<=y))?1:0; r=(m/e)-floor(m/e); s=((r<=x))?1:0; value=j||s||q;
willf ( ) posted Mon, 04 June 2001 at 4:26 PM
UUUGGGHHH!!! I got "into" art to get "outa" math. Those formulas make my head spin! Good start on that pyramid formula twillis.
twillis ( ) posted Tue, 05 June 2001 at 7:34 AM
Well, the corners are screwed up, and I never went back to fix it. I came to Carrara via POV-Ray, which is all formulas. Also, my art background is technical drawing. Anyway, if I had been able to use descriptive variable names, my formula probably would make more sense (there is apparently a limit to how many character you can enter in the box).
