Tue, Dec 31, 10:09 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 29 10:47 pm)
Carrara Free Stuff here.
Subject: Ocean
mhscspo ( ) posted Thu, 22 November 2007 at 2:51 PM · edited Tue, 31 December 2024 at 9:52 PM
How do you make the ocean calm or fairly calm after it is inserted into the scene. The default is way too rough.
bwtr ( ) posted Thu, 22 November 2007 at 5:19 PM
See attached, or click on the Spanner in the top RH corner of the screen.
bwtr
mhscspo ( ) posted Thu, 22 November 2007 at 6:23 PM
Thanks!!
bwtr ( ) posted Fri, 23 November 2007 at 5:20 PM
If you are trying to adjust wave speed etc, there is an adjustment spot as arrowed. Also to be clear on the workings have a good read of the Help.
bwtr
bwtr ( ) posted Fri, 23 November 2007 at 8:27 PM
You may need this information to adjust the speed correctly.
bwtr
bwtr ( ) posted Fri, 23 November 2007 at 8:29 PM
bwtr
bwtr ( ) posted Fri, 23 November 2007 at 8:30 PM
bwtr
mhscspo ( ) posted Fri, 23 November 2007 at 8:43 PM
Thanks, I had to figure out how to set the time on my own, when you pay a lt of money for these 3D programs they should at least explain things in the help section instead of just telling you what some of the features are for.....
FLYN ( ) posted Sat, 08 December 2007 at 8:31 PM
is the ocean animatable?
bwtr ( ) posted Sat, 08 December 2007 at 9:11 PM
Yes.
bwtr
mhscspo ( ) posted Sun, 09 December 2007 at 12:14 AM
Quote - You may need this information to adjust the speed correctly.
Thanks a whole heap!!
FLYN ( ) posted Mon, 10 December 2007 at 7:55 AM
Can anyone give a step by step on how to animate the ocean?
bwtr ( ) posted Mon, 10 December 2007 at 4:36 PM
The Ocean is allready "animated" which you will see if you move the blue arrow head as indicated. ALL you need to do is adjust the amount of rise and fall, speed, and wind direction. HOPE that helps.
bwtr
