-Next Press convert. select the clothes to convert, and the target directory. Then choose Convert from v3 to v3 if the character is a morph of v3 that you bought or downloaded. Or from MIki to Miki etc Also check the boxes you want for the Type of clothes and so on. Also choose the Add full body morphs box and i don't know if you want , but i usually check Keep Existing morphs.. That's good because if the original dress had morphs to adjust many things, i'm sure you'll wan to keep those. -Press convert -You'll be asked two questions in 2 different windows. One asks which morphs to keep, and the other which full body morphs to add.. or something like that, i can't recall. in any case when it asks for which body morphs to transfer, be sure your Created full body morph is there and chose it. In my case, it is there but now named "V3 SexyMargot" so i choose that one. and that's it when it finishes converting. your dress ir ready.
great! glad someone figured it out...lol
knew i was just missing something simple.
i'll try it on the one i'm working on.
netta
You can use the free spawncharacter.py python-script of svdl, it makes a INJ-file of the FBM-character. Inject that file in an unmorphed figure, save that and let it analyse by wardrobewizard 2, if nothing went wrong you have the FBM-morph in your morph-list and that can be injected in the clothes you want to convert. This works super!
The python-script can be downloaded from the free stuff of svdl.
Good luck
Bopperthijs
This may help PC & Mac
I've been informed of the DeltaX15 Daz Studio script that will analyze the figure in the scene and deliver a CR2 file containing all the correctly formed morph and full body morph data.
http://forum.daz3d.com/viewtopic.php?t=44893
In DAZ Studio loaded V4 with all here morphs
Ran the DeltaX15 script
Selected all the morphs that are actuated by sliders in the BODY section. (Or as many as I wanted).
Used the V4 Base as the donor CR2
Pointed Wardrobe Wizard 2 at the New Base.CR2
It recognized all the morphs and analyzed them.
Then converted P4 Catsuit to V4
Loaded converted suit into the scene.
Tested all the dials in the BODY section.
All worked except "Strength" which wasn't a morph in the first place. I'd simply selected it without thinking.
Problem solved.
Please let me know if this (a) works for you and (b) is what is needed.
Thanks.
I have to add some warning to my advice, I discovered that there are some big disadvantages to this method when working with V4.1: crosstalk doesn't work anymore and the eyes are dislocated!
I'm trying to figure out a solution but I'm afraid it's a Poser7 thing and I haven't P6 not installed at the moment. So take care for now!
Best regards,
Bopperthijs
