Sun, Jan 26, 6:22 AM CST
Subject: WW2 conversion question
martial ( ) posted Sun, 25 November 2007 at 3:21 PM · edited Sat, 25 January 2025 at 12:35 AM
Bonjour I test today Wardrobe 2 Wizard bought this week .I used stand alone version Seems good for some conversions i did except this one I test with a complicated skirt made for V3 (DNA) Also with belt same problem) The cr2 producted (keep morphs quoted) have a problem (see pict) So i get a look to the obj producted by WW2 in Geometries folder and the mesh converted is good (see it when i import the meshe in Poser 7) As Cr2 is suppose to load the obj i don't why this problem arrive Any idea to correct this ) Thanks
BAR-CODE ( ) posted Sun, 25 November 2007 at 3:29 PM
Maybe you go to PhilC site and join the WW2 forum ..to get the fasted answers ..
And for Phil is much easyer to keep track of the questions that people have.
But knowing Phil ..he will show up here to anwser ..
And just a tip ..next time TYPE the info into you images ..i cant read what you'r write .. 😉
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
PhilC ( ) posted Sun, 25 November 2007 at 3:42 PM
Its not so clear from your image. Are you saying that a section of the dress is missing? If so what was the group name of the missing part?
martial ( ) posted Sun, 25 November 2007 at 4:42 PM
Bar-code:i will follow yours suggestions next time
Hello PhilC This was an exception Your soft is fantastic Many clothes converted this afternoon were ok
For the problem .In cr2 (at left) some part of the skirt (one with a cercle) are not suppose to be there
At right you will see the geometry produced by WW2. It is correct without the part in front  like the one you see in the render from Cr2 conformed on V4 (at left)
Sorry if my explication aren't enough clear .I am a french speaking person and i don't find  always the  correct words in english
Gareee ( ) posted Sun, 25 November 2007 at 5:35 PM
Phil.. looks like a layered skirt, and the top layer is completely missing. I supposed it could be polys facing the wwrong way in preview, but they could be completely missing.
bnetta ( ) posted Sun, 25 November 2007 at 6:00 PM · edited Sun, 25 November 2007 at 6:02 PM
nope, i have that skirt it's the firedancer by little fox
the problem is a joint parameter adustment that needs to be done.
the front thigh is sticking out funny.
in poser7 you will need to open the joint parameter window and slightly turn that particular part of the skirt dial until it goes away. then resave the character.
hope this helps ya
i would convert this skirt with the loose skirt and flair settings
netta
philc 's site has a simple tut on how to do this.
www.oodlesdoodles.com
PhilC ( ) posted Sun, 25 November 2007 at 6:02 PM
I suspect it is a body part with a non-standard name.
Do this.... Convert with the As Prop box selected and the Regroup box unselected. Does the skirt part remain?
If OK apply the figure file from the first skirt. Do this by taking the new skirt prop into the set up room and double click on the first converted skirt's library thumbnail. You'll then need to add a bone and name it to match the extra skirt group name.
That will probably need further explanation but try that and see how far you get.
toolstech ( ) posted Sun, 25 November 2007 at 6:20 PM
From the image, it looks like a joint parameters issue around the thigh/knee.  I've got the same FireDancer outfit.  It is one that I know in the past has given me problems with the original Wardrobe Wizard, so I tested the conversion with version 2 as well.
It definitely works much better with the new WW2 release.  It appeared to work fairly well for me when I chose the "Loose Skirt" option for both the belt and skirt.    Attached is a comparison picture.
On the left, V3 with the original FireDancer outfit
In the middle, V4.0 with the original WW conversion.  No joint parameter adjustments.  (the hair is from the new WW2 conversion, I didn't take the time to convert that under WW1).
On the right, V4.0 with the new WW2 conversion.  No joint parameter adjustments.
Note that my conversion from the original WW had much the same problem.  The only problem I seem to have with the new conversion is at the base of the skirt.  And I think this could be taken care of with a bit of joint parameter tweaking.
martial ( ) posted Sun, 25 November 2007 at 6:38 PM
Your are right Toolstech
 It was working now with your suggestion
Again PhilC :i  am so happy that WW2 woks also with morphs Many thanks!
V4 looks as pretty as V3 with Firedancer outfit
