Tue, Jan 14, 5:17 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Carrara Free Stuff here.
Subject: Poser scene props not importing to correct location
UofOstudent ( ) posted Fri, 30 November 2007 at 10:20 AM · edited Tue, 14 January 2025 at 5:05 PM
I have a couple of poser objects, both in pp2 and cr2 formats, that when used in poser are designed to be in predetermined locations; mostly they're buildings, etc.. designed as part of a scene package.  Is there a way to make them show up in the right place when I open them in Carrara?
GKDantas ( ) posted Fri, 30 November 2007 at 11:17 AM
Drag it to the model or part of the model in the instance window, not to the assembler window. Need to work this way.
Follow me at euQfiz Digital
UofOstudent ( ) posted Fri, 30 November 2007 at 1:21 PM
Quote - Drag it to the model or part of the model in the instance window, not to the assembler window. Need to work this way.
The problem is, though, that while that seems to work for smart props which are parented, it doesn't seem to work for props/cr2s that have built-in offset coordinates and thus aren't parented to anything but shouldn't load at 0,0,0 either.
GKDantas ( ) posted Fri, 30 November 2007 at 1:47 PM
I understandnow... Tell  me one prop that happen this and Iwill try here, if dont getit to work will reportas  a bug to Daz.
UofOstudent ( ) posted Fri, 30 November 2007 at 1:54 PM
Quote - I understandnow... Tell  me one prop that happen this and Iwill try here, if dont getit to work will reportas  a bug to Daz.
One example I can think of would be the furniture in the Home One series......
GKDantas ( ) posted Fri, 30 November 2007 at 2:28 PM
Send me a link tothis product please
DocMatter ( ) posted Mon, 03 December 2007 at 6:48 PM
This has happened to me for a couple of props, most recently the Dream House rooms from Daz.  When I drag them into the scene, they don't line up.  However, I then noticed that if I move the Hot Spot on each to 0, 0, 'whatever', they then line up like they're supposed to.
This , at least, worked for me in this instance.
GKDantas ( ) posted Tue, 04 December 2007 at 4:49 AM
I reported the issue to the Daz  Bugtrack, lets wait some news.
GKDantas ( ) posted Tue, 25 December 2007 at 6:08 AM
News to you! To place almost all props in place just drag it to the instance window or over the Scene word in the intance window and it will be placed in the right position. A friend told me this after a little talk, so thanks to Naomi for this trick!
