Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 1:47 am)
Thanks, however, I tried that to no avail. I am using Poser 5 and i tried the poses with the lip couch prop. If I try a pose that was not purchased specifically for the couch, the model gets stuck in it. Once the model is posed with the poses that came with couch she is stuckand can't be moved without moving the couch also??
Please let me know what other info would help you help me.
Thansks,
Is the couch the prop you are refering to? Did it come with poses to pose a figure on the couch? You need to be more specific about what you have, and what you are doing.
If this is a purchased product, then you would be better off contacting the creator. Someone might come along who is familiar with the product, but you would be more likely to get the help you need from the creator.
John
Let me see if I understand you correctly.
You have a couch prop. You load a character, then load the couch. At this point you can translate the 'Body' actor of the character without the couch moving, right?
Next you apply a pose that came with the couch to the character. Now when you translate the 'Body' actor of the character the couch also moves?
Please confirm the the above is a correct statement of your problem.
I have purchased a prop with poses attached. When I try the prop with other poses, it does not work. The model and the prop are attached and I can't get them unattached. Can someone tell me what I am doing wrong or direct me to a tutorial that can help me?
Thanks in advance,
