Sat, Jan 11, 10:05 AM CST
Subject: Exporting objects re-import 25 times LARGER!!
hamiltonpl ( ) posted Tue, 04 December 2007 at 9:53 AM · edited Sat, 11 January 2025 at 6:17 AM
I am working with some props and have them as I want them. I export as OBJ. Then for some reason when I import them back into the Poser scene they are HUGE!! They are scaled at 100% at this point but to get them back to size I have to re-scale them after the import to about 4%.
What is going wrong with this? tks
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
PhilC ( ) posted Tue, 04 December 2007 at 10:12 AM
Does your modeler scale on load/save?
What import options have you selected?
Do not select % figure height.
hamiltonpl ( ) posted Tue, 04 December 2007 at 10:20 AM
I had the % of Figure Size selected. Why wouldn't this be standard at 100%?  Not very intuitive. But deselecting does bring the object in properly....thanks Phil!!    phil
BeyondVR ( ) posted Tue, 04 December 2007 at 12:03 PM
Uncheck all the OBJ import options and it will come back in at the same size and position, and all parameters will be zeroed.
John
kuroyume0161 ( ) posted Tue, 04 December 2007 at 1:47 PM
Figure Size is definitely a bad name for that option.  It makes sense only if you understand how it works - then I'd still avoid using it! :)
What it means is that there is a 'standard' Figure size.  At 100%, the object being imported will be scaled to fit that size (no matter how big or small it really is).  At any other percentage it will be scaled additionally to that percentage of that size.  This option might be useful if you know that your object is 'twice as big as' (however that is to be interpreted) as a Figure (?) - then you would use 200%.  Got me...
 -- Bjarne Stroustrup
pakled ( ) posted Wed, 05 December 2007 at 12:31 PM
Poser has 'size issues'...exporting and importing can make Poser stuff tiny, and object files huge. I remember my first helmet prop came in large enough to bathe in...;)
hamiltonpl ( ) posted Wed, 05 December 2007 at 11:45 PM
Very non-intuitive. I read the help document and finally understood to what it meant by figure size.  To me importing the prop in original size is what you would want.  You could always rescale. I also have been using VUE and it does something similar but I always leave the scaling alone while importing and then work on the object once it makes it to the scene.
