if that's what it's supposed to do it makes a right pigs ear of it :$ I never use it because it makes posing really quite a lot harder than it needs to be
My Freebies
Buy stuff on RedBubble
How to use it? load your figure, turn on Auto Balance, start posing. You should not normally need to move the CenterOfMass prop. Moving the CenterOfMass prop changes where Poser thinks the center of mass is. For example, supose your figure is carrying a heave weight in its left hand, Poser does not know that the thing in the left hand is heavy. You could shift the CenterOfMass prop to the left to make the balance more realistic.
@ FrankT, I never use it either!
It doesn't seem to do much more than IK. You can get the same
effect by moving the Hip around with the feet IK'ed. I suppose the
auto-balance does restrict the leg moves some, but with a little
common sense you can avoid physically impossible poses anyway.
My python page
My ShareCG freebies
P.S. If you apply a pose from a Pose pallet whilst Auto Balance is turned on, nothing happens at first, when you click on a body part in the document window Auto Balance springs to life and your figure is balanced, if you are lucky, or twisted into some grotesque contortion if you are not. The final pose can be diffrent depending on which part you click on, in my limited experiance a foot is a good choice, the hip is a bad choice.
Auto balance is great... for comedy poses. Yes, I use it on a daily basis.
I thought auto-balance was intended to be used after a pose was finalized, as kind of a correction for impossible poses. That's how I'vew tried to use it, in the past. I don't recall that the results were so bad, but then my posing skills are pretty bad anyway, so maybe it could only improve things for me....
I'm gonna have to try using it while posing now, however....
Somebody please tell me. I read the Poser Reference file and I still don't understand how to use Auto Balance (in Figure Menu) or what does it do...
Thank you!
