Sun, Nov 24, 2:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 1:33 pm)
Subject: Attn: Computer Gurus - Better performance Poser 7 and XP ?
shadownet ( ) posted Mon, 10 December 2007 at 12:52 PM · edited Thu, 21 November 2024 at 2:25 AM
Hi,
Looking for any tweaks, tip, tricks, etc. to get Poser 7 to perform its optimal best on XP.
I have a 2.66 Intel Processor (dual core) with 3.0 GB RAM, ATI Radeon w/ 256 MB, and huge free hard drive space.
I have found using Rambooster helps, but  I still get "out of memory error" when trying to render (seperate process) large scenes. What I don't get is why I show plenty of free RAM(often 1024 mb or more) available when I get the OME????
Rob
kuroyume0161 ( ) posted Mon, 10 December 2007 at 2:46 PM
'Cause 32-bit processes only get 2GB max normally.  You could have 300GB and it won't help Poser running out of memory...
There is a thread here on getting Poser to use more memory (up to 3GB) - it requires some fiddling with Poser and the OS boot ini.
 -- Bjarne Stroustrup
svdl ( ) posted Mon, 10 December 2007 at 3:36 PM
Poser 7 does not require fiddling. Windows does.
Open boot.ini from your C: drive in Notepad and add the text "/3G" after the text "/fastdetect". This will make Windows allow up to 3 GB of address space per process. Now both Poser 7 itself (integrated renderer) and FFRender can use up to 3 GB of RAM (virtual or physical) for rendering.
My gallery   My freestuff
shadownet ( ) posted Mon, 10 December 2007 at 4:33 PM
Thanks for the info.  This explains why upping my system to 3 GB over 2 GB did not show me any marked improvement.   The notepad edit looks simple enough, will definitely give this a whirl! :O)
pakled ( ) posted Mon, 10 December 2007 at 8:25 PM
there's also something with buckets in Poser memory...vague on that, but maybe it will job someone's memory...;)
ghonma ( ) posted Tue, 11 December 2007 at 2:36 AM
Quote - add the text "/3G" after the text "/fastdetect"
'/3GB' not '/3G', see here for more info:
BOOT.INI
Also make absolutely sure to back up the 'boot.ini' file somewhere safe. One mistake in it and your system will refuse to boot anymore till you fix it.
shadownet ( ) posted Tue, 11 December 2007 at 8:13 AM
Hi Pakled, the bucket size can be reduced to save memory and can also be set to adapt itself as needed, not sure if that option applies when rendering in a seperate process.  You can lower the bucket size in the Render editor and this does help, say if you have a bucket setting of 64MB and get an EOM you can reduce it to 32 or 16 and often FF will render.
ghonma, thanks for the additional info.  I saw the 3G and thought maybe it should be 3GB.  Definitely backed up the ini.  :O)
shadownet ( ) posted Fri, 14 December 2007 at 3:23 PM
Another question (or two) .  :O)
Would setting Performance Options (system properties) Memory usage from Programs to System cache help? hurt? or not really make much difference?  Tested this (only a few times) and I could not see where it made much difference, so am curious.
Also, when setting the page file(s), is there any particular do's & don'ts I should know so as to get best results there?
Thanks again.
:O)
Telecino ( ) posted Sun, 23 December 2007 at 10:21 AM
To lower the memory usage of my scene and be able to put much more people and clothing, i use DownRezer, that helps manage the size of texture files loaded. You can search Renderosity about it. It works great.
I'm a dork, animating dorks: www.TheDorkers.com
shadownet ( ) posted Sun, 23 December 2007 at 2:16 PM
Hi Telecino,
Thanks for the tip!  Will check it out!  :O)
Happy Holidays!
