Hi,
Thanks, I had mixed results with the built in shaders, I found the glacier to be very blue and not quite what I was looking for, and for some reason the snow shaders when rendered had lines going across them, not sure if that was the shader of the the actual terrain(2048x2048)
Thanks
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
Thanks bwtr, shaders received and I will be using them tomorrow, will let you know how it goes :)
Jon
Does Carrara Standard 5 do translucency at least? It is a big help when making ice.
I don't have C6. I'm waiting for version 7. So it will be awhile before I can play with In-Scattering, myself.
I'll upgrade Carrara when it can do SSS at least as well as Vue 6.
Its SSS doesn't do skin very well. It's the same as C5's SSS. It can do a candle or a bar of soap somewhat. But not marble statues or icebergs.
Those are perfect for liquid, such as lake depth, vats of boiled lard, sewage muck. But not for skin bags containing water (aka humans) or other solids. If SSS (which is for solids) were improved in C6 by now, we'd be seeing some better Poser renders of SSS skin here. Maybe Carrara 6.1 will have this new SSS feature? Earlobes are in dire need for some real SSS rendering.
I post, at the Free Stuff, the Ice Shader. Requires MipMapper (free) plugin from Sparrowhawke 3D:
http://www.renderosity.com/mod/freestuff/details.php?item_id=48178
Read the details and happy rendering! ;)
Attached Link: http://ciadasideias.com.br/noviski/imagens/ice_cube.zip
Sorry, about it, Shonner. Now the link is fixed.Thanks!!!
Hi,
Does anyone know where I might find a good ice shader for Carrara 5 Standard? I have tried the glacier and snow shaders that come with Vue, but really I am looking for an ice shader, something that is good close up.
Any help appreciated.
Thanks
Jon
