Tue, Dec 31, 9:10 PM CST
Subject: Vue Patch
mhscspo ( ) posted Wed, 19 December 2007 at 12:47 PM · edited Sun, 29 December 2024 at 3:38 AM
I'm trying to install the patch in Vista Ultimate 64, it keeps saying unable to locate application file, anyone using Vista can help me on this one?
bruno021 ( ) posted Wed, 19 December 2007 at 1:53 PM
Did it work with previous updates? Are you running Vue as administrator?
FrankT ( ) posted Wed, 19 December 2007 at 2:13 PM
you might want to hold off on this update - there is a problem with it.  E-On will be releasing an update for it soon
My Freebies
Buy stuff on RedBubble
mhscspo ( ) posted Wed, 19 December 2007 at 7:26 PM
Quote - Did it work with previous updates? Are you running Vue as administrator?
[No I wasn't, but I am now Thanks..
mhscspo ( ) posted Wed, 19 December 2007 at 7:28 PM
Quote - you might want to hold off on this update - there is a problem with it.  E-On will be releasing an update for it soon
Ok!
ShawnDriscoll ( ) posted Wed, 19 December 2007 at 7:33 PM
What problem is that?
dlk30341 ( ) posted Wed, 19 December 2007 at 7:36 PM
Older scenes crashing & working in the material editor causing crashes.
ShawnDriscoll ( ) posted Wed, 19 December 2007 at 7:39 PM · edited Wed, 19 December 2007 at 7:40 PM
I had not realized a patch came out again so soon.  Thanks.  I'll wait then.
Arraxxon ( ) posted Wed, 19 December 2007 at 9:19 PM · edited Wed, 19 December 2007 at 9:34 PM
I've had no problem to install the newest build 292300 on my Vista Ultimate 64bit - i don't run Vue in administrator mode, but still Vue and all updates are working fine, so it's not a necessity.
The offical, non-beta state version  of Vue Infinite is  version 6.10  build 291050.
Nevertheless, the version 6.50 and all it's build-versions are still in beta, so errors/problems can be part of it. By finding and reporting errors you will help to get this version into a final offical version status in the near future.
One of the problems with the newest beta-update build 292300 on Vista 64bit - with or without the newest Vista SP1 Release Candidate 1 update installed - is a problem with material assignment to any object.
This will be taken care of right now, as it got reported right after the release of build 292300.
To get rid of those problems for now just roll-back to the before beta version build 292230.
wabe ( ) posted Thu, 20 December 2007 at 1:08 AM
Could it be that you try to use an update on the prerelease version? Sounds a bit like. If so, get the final version at e-on as download and try it with that.
mhscspo ( ) posted Thu, 20 December 2007 at 2:37 PM
Quote - Could it be that you try to use an update on the prerelease version? Sounds a bit like. If so, get the final version at e-on as download and try it with that.
Thanks for the feed back, I got it to work by using "use as admistrator", this is the first time that I used Vista..
