Sun, Jan 12, 3:38 AM CST
Subject: How do you lengthen/shorten limbs on a V3 character?
moushie ( ) posted Thu, 20 December 2007 at 11:23 PM · edited Sun, 12 January 2025 at 3:35 AM
Is there a way to shorten or lengthen limbs on a V3 character in the baffling absence of xyz dimension controls?
jonnybode ( ) posted Fri, 21 December 2007 at 1:11 AM
Hi there!
Go to
www.daz3d.com
Browse to support/downloads/victoria
There you will find
"Victoria 3.0 Base
Victoria Updates SAE Updates scaling in arms and hands, some morphs.
Regards / Jonny
lesbentley ( ) posted Fri, 21 December 2007 at 5:14 AM
file_395947.TXT
I don't have the standard V3, but I do have V3 RR (reduced resolution) this figure does have all the scale channels in the legs.
I find it hard to believe that V3 does not have the same scale channels. Have you scrolled right down to the bottom of the paramiters pallet? I suppose it's possible that the scale dials have been hidden in V3, though I can't think that why DAZ would do that. If they have been hidden then a pose file should be able to fix that. Try the one attached above, save it to a poise folder without the ".TXT" part of the file name.
pakled ( ) posted Fri, 21 December 2007 at 7:18 AM
yup..the dials I think would be the thing. Unless you have a rack...;)
moushie ( ) posted Fri, 21 December 2007 at 11:12 AM
Many thanks Stormchaser. I've downloaded that file -- not checked it out yet -- but I'm confident that will do the job.
lowpoly ( ) posted Sat, 22 December 2007 at 4:21 PM
I just use the built-in dials (or maybe I'm not understanding question right)
moushie ( ) posted Sat, 22 December 2007 at 5:10 PM
Sorry, I meant V4, not V3. It  has an overall scale dial for each limb but no x. y, or z.
JQP ( ) posted Sat, 22 December 2007 at 7:44 PM
There's a freebie somewhere, utility pose that will show the dials (on most anything I've tried, not just V4), search for Reveal V4 Scale Dials.
