Judy is still supported in Poser 7. What you're probably running into is the fact that Poser has a bad habit of loosing the ability to recognise figures that have been saved after they've already been in the faceroom once. It saves them with totally new OBJ files which are no longer recognised as the original figure.
What do I do t fix this, work around it., or what ever so I can get Judy to look like I want?
Start with a freshly loaded Judy who hasn't been in the faceroom before and she should work just fine. That's only if the problem you're experiencing is the one that I described. If you're having trouble getting a completely faceroom virgined Judy to work in the faceroom fresh from the library, I don't know the answer.
I'm wanting to use the face room for morphing Judy but it says she's not supported (in poser7). I know it can be done with p5. Why can't I do it inp7? Is there something I need to do first or is she just not supported anymore?
