DejaVue hair I believe is for A3 so what you'll probably have to do is load it but not conform it then use the poser movement tools to move it into place if it doesn't have any dials. The head might have the trans/scale/rotate dials in it though. once you are done, parent to V4s head and you should be good to go
My Freebies
Buy stuff on RedBubble
**saus69 - Take it easy, I know how frustrating this Poser stuff is. Here's a link for the V4 DejaVu hair:
**www.3dcommune.com/3d/store/more_info.mv
**It's quite dear as it's part of a bundle.
Do you want me to try & replicate what you're doing? I can load up a base V4 & try & fit the V3 DejaVu hair to her.**
It's ok..
It's been some months before I last played with poser so I must be forgetting something.
what I did was load up V4.0, run the nanette FB morphs on it, and then load up V3 Dejavu hair. Doesn't conform at all; it ends up looking too stretched vertically. Dial and buttons for translation and scaling do not work at all; nothing happens and the values hover around 0.0000x rather than 0.1.
I'll check out the new hair pack first.
saus69 - I know what the problem is as I just tried to work it out. The dials on the hairs body won't work because it's locked. Go to 'object' & uncheck 'lock actor'. Now you can translate the hair & fit it. I hope you can now get this working, it will save you having to buy it for V4, unless you want to do that anyway.
BTW, good choice, Fabi's hairs are some of the best out there.
I actually forgot I had that hair for V4 :) thanks for the reminder heh. Renders lovely in Vue too
My Freebies
I just loaded up DejaVu hair and added it to a V4 figure.
However, it doesn't align with the head properly.
So what I did was try the ytrans dial, but the hair just refuses to move. In addition, the dial increments are very small, almost like something is preventing the dial from sliding. Manually entering a value doesn't work either as it is reset to zero as soon as i press enter.
Does anyone know what's wrong?
