Wed, Feb 5, 2:09 PM CST
Subject: Mouth Morph Dials in P7
bishop666 ( ) posted Thu, 27 December 2007 at 8:59 AM · edited Wed, 05 February 2025 at 2:03 PM
Hi:
Is it possible to add to P7's Phoneme creating mouth morph dials by creating custom dials and if so, how does one go about doing so?
Thank you in advance.
bishop666 ( ) posted Fri, 28 December 2007 at 5:31 PM
Am I to assume, by the lack of reponse, that it is not possible to create additional mouth morph dials for the purpose of adding phonemic morphs?
estherau ( ) posted Fri, 28 December 2007 at 6:09 PM
nah - just everyone is away for xmass. You just zero back all your other dials then creat full body morph. love esther
MY ONLINE COMIC IS NOW LIVE
bishop666 ( ) posted Sat, 29 December 2007 at 9:22 AM
Hi Esther:
Thank you for your reply.
By full body morph,  are you suggesting the creation of a morph target on the morph page?
Regards,
Ron
markschum ( ) posted Sat, 29 December 2007 at 10:06 AM
To create a morph you make the morph you require , either with magnets , a combination of existing morphs ,and export the modified geometry . Or by exporting the mesh to a modelling program and altering it .
Then you can take the new geometry and create a morph dial for it .
Some of the phonemes used by things like Mimic are I beieve simply the Mouth open , etc , dials.
bishop666 ( ) posted Sat, 29 December 2007 at 11:48 AM
Hi:
Thank you for the information.
I understand the requirements for creating a morph but I am not clear on how one goes about creating a new morph dial.  If I create the morph and then export it, and assuming that I am doing all of this with Poser 7 alone (no additional external software), where do I export it to?  And if it is to be re-imported back into P7, how do I then create the new dial?
Thank you in advance,
Ron
bishop666 ( ) posted Sat, 29 December 2007 at 12:35 PM
Hello once again: Well, i believe that I may have answered my own question. By simply using the "Spawn Morph Targets" choice I was able to create a new mouth morph dial. Thank you all. Ron
estherau ( ) posted Sat, 29 December 2007 at 5:01 PM
yep - that is the way to do it. Then click on reset figure, then dial your new dial to one and you will see your change. Love esther
bishop666 ( ) posted Sun, 30 December 2007 at 8:54 PM
Hi Esther: Thank you for your past assistance but it seems that I have run into a bit of a glitch with the mouth morph dials and certain props. For example, when using an M3 figure and applying a DAZ beard, adjusting the injected mouth morph dials causes the beard to conform to whatever posture the mouth or lips assume. If, on the other hand, I zero all of the dials and then spawn a new mouth morph dial, subsequent adjustment of that dial does not allow the beard to conform to the newly postured lips. If i zero that dial once again and try to recreate the same phoneme with the originally injected dials, the beard conforms perfectly. I have parented the beard to the figures head but to no avail, the same problem exists. I suspect that I am missing something crucial in the creation of the morph dial since I assume that the newly spawned morph is nothing more than a copy of the changes made by the injected morph dials that were employed in its creation. Do you have any ideas??? Thank you in advance, Ron
estherau ( ) posted Sun, 30 December 2007 at 9:31 PM
hmm - odd. in poser preferences have use external binary morphs unchecked. see if that helps. reload the beard and conform it again - does that help? otherwise try the beard with a dial up face of your morph, then when the beard conforms perfectly, try spawning a dial for the beard to match?
bishop666 ( ) posted Mon, 31 December 2007 at 10:10 AM
Good Morning Esther:
Thank you for your thoughts.
Actually, I tried all of your suggestions prior to placing my post.  It would appear that in the process of spawning a morph target, something is being ignored.  The created morph works fine without the facial hair (beard) but for some reason ignores its conforming characteristics.  I have no idea where to go from here in order  to rectify the problem.
Happy Near Year,
Ron
bishop666 ( ) posted Mon, 31 December 2007 at 5:04 PM
Hello again: It appears that the "beard" is loaded as a second figure rather than a prop. As such, it contains a host of its own morph dials including the phonemic equivalents of the primary figure, M3. If I create a spawned morph dial and then make the same changes on the beard's built-in morph dials the beard conforms properly (unfortunately, this is not a workable scenario for a lip-synched character). Spawned beard morph dials do not work either and exhibit the same problem as the M3 spawned morphs. So, it appears that unless I missed a crucial step in the creation of the spawned morphs, that phonemic morphs will only work on the primary figure, which means ... no beard. On the other hand, I guess an alternative would be to import the figure (character) into Cinema 4D or Maya and create the facial and all other hair from within those programs. It is indeed a consideration for future projects but certainly not for an ongoing project. Have a happy New Year, Ron
estherau ( ) posted Mon, 31 December 2007 at 6:44 PM
Hi ron, sorry to hear it hasn't worked. What a pain. I have C4D too put have never tried bringing hairy things into poser. Love esther PS let us know how you get on.
lesbentley ( ) posted Mon, 31 December 2007 at 7:55 PM
Attached Link: http://www.rbtwhiz.com/rbtwhiz_ERC.html
I think I know what is happening. The morph channels in the beard will use ERC slaving to slave them to morph channels in the characters head. So the built-in morphs in the beard will already be set up to slave to the built-in morphs in the head when the beard is loaded.
You would need to edit the beard in a text editor to slave the appropriate morphs in the beard to their counterparts in the head.
See link at top of this post for more details on ERC.
lesbentley ( ) posted Mon, 31 December 2007 at 8:17 PM
The code you would need to add to the channel in the beard that you want to slave to the channel in the head would be:
                        valueOpDeltaAdd
                                Figure
                                head
                                nameOfMorph
                        deltaAddDelta 1.000000
Where "nameOfMorph" is the internal name of the morph in the head that you want to slave to, eg "Mouth O". When you want a channel to slave to a figure that is not the figure that contains the channel, you should omit the figure and actor numbers, eg use: Figure
head
NOT:
Figure 1
head:1
This way the channel will slave to a channel in the figure that is currently selected in the scene when the beard is loaded.
bishop666 ( ) posted Tue, 01 January 2008 at 12:24 PM
Hi Lesbentley:
Thank you for your assistance, your explanation makes good sense and I will give it a try.
All the best for a happy new year,
Ron
bishop666 ( ) posted Tue, 01 January 2008 at 3:54 PM
Hi Lesbentley: Well, you were right on the mark! I made the suggested additions to the corresponding beard channel using a text editor and it works perfectly. Thank you once again, Ron
